Thread: cd30 to cd30 mp3
    Feb 2006
    newcastle
    Default cd30 to cd30 mp3
    hi all
    i have a vectra c sri on a 54 plate with a cd30 in it,i have a mate who has a astra cd30mp3 who is willing to do a deal on it with me.
    i have spoke to vxl main dealer they reckon that it will not fit and my vectra will not run right as the stereo is coded to the car through the ecu.
    if i do get one it has to be one out of a vectra, it then needs to be hooked up to the computer to reprogram the code
    it sounds a load of xxxxxx to me but i don't want to go to all the hassel to find out they are right.
    can anyone confirm this or has anyone tried it and succeded
    cheers john
    Wiltshire
    2 things:
    1. The Astra CD30 is a different colour to the Vectra one.
    2. It has a different shaped front panel and so probably won't fit anyway. If you look at the Astra dash it has a slight angle/crease down the centre that the Vec does not.
    Your best bet is to keep looking on ebay for a Vectra one, as the spiel your dealer gave you is probably correct.
    Wiltshire
    Jan 2006
    Leeds
    your dealer is correct if you look on your pass card for the car it will have a security code this is for your radio and immobiliser and many other things on the car.
    If you take your radio out and put it back in the code stored in the ECU will regonise the radio and it will be fine, but if you put a different one in it will come up and go into safe mode and you will need to goto vauxhall to have the ecu re-coded.
    Feb 2006
    newcastle
    thanks for the reply's
    will keep loooking for one.
    one last question
    if i put a mp3 player in (sony) will i still have the computer functions / display or will i loose them as you start comp display from original stereo.
    john
    Wiltshire
    Computer stays working. The ability to set the clock goes. You either have to stick the CD30 back in or take it to a dealer as far as I can make out.
    Regular Member pauls898's Avatar
    Malvern
    No mate you can set the clock manually, (Using the trip computer controls buttons). I have removed my original ICE and the Clock, Trip Computer all still function fine. As the guy said you will just loose the RDS time setting, so if you take off your battery you need to manually set the time and date again. I just set mine off my Sat Nav clock about once every three months as it does drift out slightly, but only by a few seconds
    Wiltshire
    You have an 03 car. On 54 reg onwards the steering wheel is different and the only way of adjusting the clock manually is by pressing the settings button. This button is on the CD30 head unit. If you've removed it, you don't have a button to press!
    I've had my radio out a couple of months and the clock is about 4 minutes fast now. Come the end of March it'll be around 55 minutes slow!!
    Malvern
    Sorry to hear that matey, I knew the newer vecties were different as have different cam buses etc, but I'd thought you could have still set the clock ! Obviously VX don't want you removing their Radios as they seem to be getting more intergrated with the car electrics.
  1. Fitting Parrot MKi9200- Can it run through CD30 aux?(does CD30 even have aux!?)
    By dibble750 in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2013, 02:20
  2. Quick CD30 to CD30 MP3 question
    By Chip in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2012, 00:47
  3. Cd30 & bid
    By KyleSxi in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2012, 15:50
  4. CD30 to CD30 MP3 Conversion
    By yysnet in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 00:20
  5. Replacing CD30 with CD30 MP3
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 15th August 2007, 13:38
