Thread: Leaking oil from filler cap..
    Regular Member macdad's Avatar
    Dec 2007
    East Midlands
    Default Leaking oil from filler cap..
    Anyone got the problem as i have with a leaking oil filler cap collecting in a pool of oil shown in pic,got hold of a cistern coupling washer from b&q for £1. 80 placed it round the cap ..perfect fit and hey presto ..no more oil leaks
    Jan 2006
    Hornchurch
    the o ring on the std caps dose let oil past
    Regular Member m_r_shaw's Avatar
    Sep 2007
    Sunny Waterloo, just outside Liverpool.....
    i had same problem on my dti, so i bought a new filler cap.......still leaks have you got the exact details of the rubber ring mate?
    Dec 2007
    East Midlands
    Quote Originally Posted by m_r_shaw View Post
    I can measure it m8 find exact size..but went to b&q in the plumbing section and it is actually a washer used to seal toilet cistern coupling pipes,if you have b&q near you,you'll see it in there.
    Sep 2007
    cheers macdad. i'll look tomorrow
    Apr 2006
    Kingswinford
    Trim : LS
    Engine : 2.0 DTI
    Year : 2003
    Mileage : 150000
    Superb, I'm constantly wiping the oil off the mentioned area. I'll pop to B&Q and purchase the washer.
    Many Thanks
  1. Best Oil to use and where does it go(apart from the oil filler)
    By caravaner-tony in forum Engine & Drivetrain
    Last Post: 30th August 2010, 21:23
  2. Oil Filler Cap
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 12th July 2008, 12:53
  3. Filler
    By Ste in forum General Chat
    Last Post: 3rd February 2008, 21:11
  4. how much is a filler cap?
    By corman in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 22:14
  5. Filler Cap
    By MLC in forum Vectra C / Signum Car Chat
    Last Post: 17th August 2005, 08:07
https:www.vectra-c.comforumshowthread.php54649-Leaking-oil-from-filler-cap
Vauxhall combo oil coming from filler cap
Vauxhall combo oil leaking from filler capAstra 1.7 cdti oil leak from filler capcombo 1.7 di oil coming from filler capvauxhall zafira leaking oil from oil capvectra blowing oil from filler capoil leaking from oil filler cap zafiraopel astra g leaking deselHow to spot oil leaks on 1.7dti engineleak oil filler cap opelopel astra oil capzafira mk1 filler cap o ringleak around oil cap vectra coil leak from oil filler cap astracombo 1.7 dti oil coming from the filler capvauxhall zafira leak from filler capvauxhall zafira oil cap leakingvectra c oil cap2.0dti vectra blowing oil ouy of filla capvectra dti oil breather cap leaking
