Thread: rear piston wind back
    warrington cheshire
    Default rear piston wind back
    rear piston turns but not winding back,do I need to disconnect hANDBRAKE CABLE? open bleed nipple? or am i missing something
    Mileage : 55000
    How are you turning the piston?? are you using a piston re-wind tool as you need to turn the piston AND push it back at the same time.
    warrington cheshire
    many thanks, Turning piston clockwise with piston tool all turns but does not go back in , any ideas?
    Jan 2008
    Bolton
    Its a swine of a job if you dont use the correct tool.
    I didnt have the correct tool and it took a few attempts.
    You have to turn it while pusshing it, relese the bleed nipple to help relieve the presure, you will loose a lot of fluid so I would make sure you can top it up.
    I got the impresion that the thred is very fine and it felt as though if your pads were quite low then it comes off the thred that why you have to push it and turn it to find the thred once found its easy.
  1. Help - cannot get brake shoe piston back in, cant open bleed nipple
    By JACKALG1 in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 14:25
  2. Rear brake calipers wind back tool - Herts
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 21:24
  3. Brake piston wind back tool?..
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 15:47
  4. Rear Brake Wind Back tool/cube
    By snapsnap in forum Handling & Braking
    Last Post: 4th November 2009, 11:48
  5. Piston Wind-Back Tool...
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2008, 14:10
vauxhall signum push rear piston back
does the insignia 2009 have wind in rear pistons
vauxhall rear caliper piston trouble winding back site:www.vectra-c.com
