Thread: massivly erratic 3.0l
    Jun 2007
    Devon
    Default massivly erratic 3.0l
    Original thread here:
    http://forum.vectra-c.com/showthread.php?t=52875
    The problem cleared up for a couple of weeks but is now back with a vengeance!
    Acceleration at any point, not just flat out, can either be perfect, or it has massive flat spots and huge juddering fits through the range 0-70mph!! Both of which is just seems to 'get over' in its own time and give me the whack of acceleration I expect!
    It also seems to at random points jump up and down in the revs 2500 to 1500 then back, then back, then back then accelerate
    Problem *seems* much more pronounced up hill
    This has happened pulling out of junctions etc so is just stupidly dangerous!
    It is booked into the stealers for Thurs but it may have cleared up by then.... any advice?
    I had the missus record the clocks while I put my foot to the floor, can link people to the video if anyone can possibly help diagnose?
    Regular Member vectravirg's Avatar
    Bolton
    Had problems with my 3.0 going into limp mode at random times if I put my foot down, sounds like different symptoms to your's but mine a replacement MAF sorted mine out.
    Jun 2007
    Devon
    Yeah the weird thing is it isn't going into limp or kicking out any dashboard lights!
    I can almost guarantee it will be fine when the garage get it which is the frustrating thing!
    Bolton
    Same thing with mine going in limp mode all the time, take it to the dealers no problem at all. Replaced the boost pressure sensor, fuel rail, manifold and eventually the MAF, so take your pick from any of them!
    Presumably a 3.0 V6 CDTI
    Mine used to do this as well
    People were suggesting all kinds of things, from clutch slip to MAF, and so on
    However, my local VX dealership finally managed to trace it to the traction control
    Does it sound like this...
    Pottering a long at a set speed, say 50mph, in a high gear, say 5th
    Want to overtake so come down a gear or two
    Foot to the floor, the revs increase but the speed stays the same
    Then the revs come back down to what they were, then the speed and revs perform as you expect
    Jun 2007
    Devon
    No the revs rarely move, it sticks totally at a set mph and set rev's the gives a whack of power
    Occasionally the revs flick up and down a bit but mostly it just sticks!
    Jun 2007
    Devon
    Fuel pressure valve apparently
    6hrs work and £600 they think, just checking if its covered under my 3rd party warranty
  1. Erratic A/C Can someone shed some light
    By looloo2 in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2012, 10:09
  2. Erratic Revs
    By kel123 in forum Engine & Drivetrain
    Last Post: 22nd August 2011, 16:08
  3. V6CDTi - Erratic idling
    By Celes in forum Engine & Drivetrain
    Last Post: 5th January 2011, 20:21
  4. 3.2 erratic idle
    By Annalogg in forum Engine & Drivetrain
    Last Post: 25th June 2010, 13:26
  5. Erratic CANBUS
    By johnmac in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2009, 22:30
