Results 1 to 2 of 2
Thread: MOT Fail. Rear Coil Spring Cracked?!
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default MOT Fail. Rear Coil Spring Cracked?!
    Hi as title suggests one of the rear coils has cracked causing the car to fail the mot. How hard is it to replace them yourself? any tips please?
    Thanks.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    This should help....http://forum.vectra-c.com/showthread.php?t=46991
    Very simple (if you have Torx sockets) Remove the bottom bolt of the dampers (shock) using a jack to support the suspension arm. Wind down the jack and the spring will become loose. Remove spring replace with new one. Wind jack up so bolt and hole are level. Replace bolt ...job done.
    Best bet is take the wheel off and have a look. You will see its really that simple....
    Last edited by John35; 2nd August 2008 at 10:53. Reason: too many bolts not enough holes
  1. Cracked foglight MOT fail ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 14th March 2012, 21:12
  2. Broken rear coil spring on 04 Signum
    By INCONTROL in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2010, 17:34
  3. MOT FAIL - Cracked Alloy - HELP?! :(
    By Vauxhall Thru & Thru in forum Handling & Braking
    Last Post: 27th June 2010, 22:33
  4. MOT Fail. Cracked VXR Wheel
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2009, 20:58
  5. Cracked rear spring?
    By alzsxi in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 21:43
