Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Big Brake kits
    Jan 2006
    Hornchurch
    Default Big Brake kits
    would it be worth making up a brake kit for the vectra C ???
    say a 6 pot kit that goes under std wheels ?? as in 17's 18's 19's
    also what would a good price be for a 6pot kit on the vectra or is the 3.2 kit fine as it is
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Are you thinking of racing the Vectra or is it just for road use??
    Regular Member shan's Avatar
    Now i like the look of those.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : saab 95
    Engine : 2.3t
    yep me too
    Jan 2006
    Hornchurch
    its just for road use an track use
    I no longer have a vectra I sold it over a year ago now
    cost wise i would say £1100 should see a kit for the vectra
    but would people pay that ??
    for a 330mm 6 pot kit with every thing needed
    could go bigger on disc size but price will go up
    and needs 18's or 19's
    under 19's you can fit a 406mm Disc
    Apr 2006
    Vehicle : saab 95
    Engine : 2.3t
    in these times of hardship id say a bit steep but to be honest the price u say is cheap just not cheap enough for me.
    Jan 2006
    Hornchurch
    i dont make them up its a company i use
    member of the smoke patrol 230bhp+
    not that good when you can get things like this for less than £700
    324 x 24mm 4 pots
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Quote Originally Posted by chrisgettings View Post
    324 x 24mm 4 pots
    Jan 2006
    Hornchurch
    324 x 24mm 4 pots
    yes they are a good price I did look at them
    but you have a small disc an thats thin 24mm with a lot of heat in them
    also it was easyer to fit bigger disc under a small wheel as you can move the disc over the hub a few mm and save using a spacer
    they are the saab kit off ebay ?
  1. Brake pipe flaring kits
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 27th January 2012, 18:32
  2. LMF Have the 314mm brake kits in stock again
    Last Post: 2nd February 2011, 18:00
  3. big brake kits
    By chrisgettings in forum Handling & Braking
    Last Post: 1st April 2008, 14:34
  4. New Big Brake Kits From LMF
    By mark1319 in forum Handling & Braking
    Last Post: 14th March 2008, 17:00
