Thread: Power to a Head Unit
    Regular Member Damian's Avatar
    Market Drayton
    Default Power to a Head Unit
    Before I took my CD30 out you could switch it on without the keys in the ignition and turn it off again.
    Since putting my new head unit in I can't do this, the ignition has to be on. This is a bit annoying because when I am polishing it or working on it I had the windows down and the stereo on. I do not fancy spending a couple of hours working on the car with the keys in the ignition and the ignition on.
    Simialry if filling up with fuel and I turn the engine off, the family can't put the radio back on without having to put the ignition on (which I am pretty sure isn't safe !!!!)
    Is this something I have done wrong when installing. I have the leads the correct way round for retaining the settings, I just want to be able to power it up without using the key. I have the Pioneer DEH70BT.
    Could this be a leftover of the 'ignition logic' setting in the CD30??
    Was the permanent live feed you used in fact the switched signal from the old setup??
    Green Growler is the man for ICE as he's done more to his loom than I or even VX would probably dare.. drop him a PM
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    hi mate sounds the same as my sony hu but what happens with mines if you switch the ignition on then off then leave keys in i the ignition it stays powered for about 30 minutes plus trip screen stays on aswell
    Regular Member grumpano's Avatar
    North West
    Damien do u want to sell the cd 30?
    Wiltshire
    Just join the yellow and red wires on the Pioneer's loom together. This will mean that your live feed and switched feed will be one and the same and the radio will work without the keys in the ignition.
    Market Drayton
    Quote Originally Posted by simonali
    How will this impact the amp I have connected. If I take the panel off the radio will this power it down therefore power the amp down
    Market Drayton
    Quote Originally Posted by grumpano
    Not sure yet, I will have a think about it
    Wiltshire
    Quote Originally Posted by Damian
    Does the head unit send a signal to the amp to tell it to come out of standby? If it does then switching off the head unit or removing the front will turn it off.
    Market Drayton
    Excellent, sounds like this is the way to go
    Many thanks
    Market Drayton
    This picture is what the connections are like on the back
    I assume then from what you are saying I join Yellow(2) and Red(4).
    How do I do this, because I currently have them plugged Red(4) to Yellow(3) and Red(5) to Yellow(2).
    Apologies if I am being a bit dense
  1. Stopping power drop to head unit
    By DNS in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 14:52
  2. head unit power feed????
    By jonny_adams60 in forum Electrical & ICE (including SatNav)
    Last Post: 13th February 2011, 17:52
  3. No Power To Head Unit (Fuse's OK)
    By Simo87 in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2009, 11:26
  4. No power to head unit!!
    By jeremy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2006, 10:14
