Thread: Misfire on CDTI SRI 1.9
    Regular Member Warrenmole's Avatar
    West Yorkshire
    Default Misfire on CDTI SRI 1.9
    Hi all
    Got the car back today after getting the airbag wiring looms fixed that were causing my Airbag light to be on...anyways after he'd finished he noticed the car has a misfire when revving the car. The car does seem to vibrate a little more than it did when around the 2k revs mark although the car drives fine and no lights on my dash??
    Any Idea's and if it is a misfire what do I do???
    Regular Member ion's Avatar
    walsall
    Get it checked mate, it could be a few things such as an injector.
    West Yorkshire
    if it is an injector how much would that cost to fix???
    Belfast
    CDTi injectors are not even close to cheap.
    Bristol
    Vehicle : CDTI 150
    COuld be the injector loom there have been a few issues with these.
    Search the site
    West Yorkshire
    where can I find the injector loom, (I've no idea about engines) what's it look like?, could I buy a new loom and replace myself??
    Bristol
    Vehicle : CDTI 150
    Vx do a repair kit about £10 for each injector. But they need to be spliced in.
    Basically if you remove the top engine cover, just a sharp tug, its held on by 4 rubber bungs.
    Running L to R nearest you, you will see 4 electrical plugs, these are the feeds to the injectors.
    I think Vx list 1.5hrs per injector as labour. So about £150 at a dealers, perhaps try a Vx specialist if you are not a dab hand with electrics.
    Hope this helps
    Les
  1. Misfire 1.9 cdti 120
    By matt2002 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 08:38
  2. misfire on a 150 cdti- help pls
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 11:21
  3. CDTI 150 'misfire'
    By lesj in forum Engine & Drivetrain
    Last Post: 12th February 2010, 22:30
  4. 1.9 CDTi MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 19th March 2009, 23:28
  5. 1.9 cdti misfire
    By johnboycdti in forum Engine & Drivetrain
    Last Post: 10th March 2007, 10:37
