Thread: Anyone fitted one of these ?
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Default Anyone fitted one of these ?
    Its a BOV HERE:
    Any one fitted one and are they worth it ?
    Tyneside
    Performance wise NO. All they do is make a noise in simple terms, but can aid to stop the turbo stalling etc, although this only really applies to high performance cars TBH.
    Belfast
    The fact that it needs electrical wiring that employs a microswitch should tell you to avoid this at all costs.
    Oct 2006
    Portsmouth
    That'll be a BIG NO then
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Dump valves work very well, as they effectively remove pressure from the manifold side of the turbo charger when the throttle is closing and hence keep the turbo spinning for longer as it is effectively not compressing any air and doing work anymore. When the valve closes the turbo will be still spinning faster and hence be able to do work immediately (ie compress air).
    Note that diesels don't have a throttle valve in the inlet manifold, so dump valves are not very effective, as there is no point.
    May 2006
    n.ireland
    Dump valves on a diesel are like nipples on a man.
  1. just fitted the k&n 57i .
    By nelly452 in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 22:49
  2. Hid fitted
    Last Post: 29th December 2010, 19:16
  3. anyone got or fitted??
    By vectra_c_wannabe in forum Electrical & ICE (including SatNav)
    Last Post: 25th May 2010, 09:50
  4. Just Fitted.......
    By KeefyB in forum Petrol Engine related
    Last Post: 22nd January 2010, 21:38
  5. Fitted for 314mm discs but fitted with 304mm discs
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 13:19
