Thread: Brakes with a mind of there own!!
    Regular Member delete2's Avatar
    West Midlands
    confused Brakes with a mind of there own!!
    Right bit odd. sometimes brakes work a charm. some times they feel like there running with just air in the pipes.
    in otherwords somtimes super stiff (which is how i like it) lol i know i can stop from speed then lol
    then sometimes really super super spongey as in im down to the floor for the brakes to work well
    odd as ive just bought the car from a Net Q dealer so id assume that it would have the brakes checked and servised?
    Would getting new pads, bleeding the system and braided hoses get rid of this?
    if so what are the best pads to get? ive heard green stuff or red stuff are the best to go for?
    ta for any help, Will
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If its deisel then that may explain it - the brakes on a deisel do not like being 'pumped' frequently as this can make the pedal go slightly 'stiff' then it 'frees up' again. But get them checked though - it's your brakes none the less.
    Gazza4
    West Midlands
    lol will do. thank goodness for warrenties. get all these niggly little problems out of the way in the first year eh i suppose.
    Jul 2006
    Where abouts in the West Mids are you m8?
    It sounds (in my less than expert opinion) like you've got air in the brake lines. If it's got NetQ warranty, get it back in and let them sort it for free.
    Sunny Dartmoor
    Definately sounds like air in the system,get it sorted m8.........
    Maida Vale
    IMHO first thing to do is get the brake fluid renewed, whether by paying for it (circa £25) or via Q warranty doesn't matter. Don't know for sure with Vauxhalls, but with some brands you can have the car serviced by their dealers every year and the brake fluid still never gets changed unless you specify it as an extra job, despite the manufacturer saying it needs to be done every 2 years. I will add you should get all the fluid renewed, not just bled until the air stops coming out.
    Jul 2006
    Mexico
    Similar thing on mine.....from the responses I got the first thing to do is purge the system of air as someone allready said
  1. Not quite what i had in mind
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 21:34
  2. my car has a mind of it's own
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2011, 22:32
  3. Mind how you go sir...
    By MrT in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 00:18
  4. bit of help if u don't mind.
    By wanna veccy in forum The 'Off Topic' room
    Last Post: 7th November 2008, 11:14
  5. Mind of it's own
    By jimmy55 in forum Engine & Drivetrain
    Last Post: 15th July 2008, 21:01
