Results 1 to 10 of 15
Thread: Door Pins - Will these fit my car?
    Regular Member sduk's Avatar
    Dundee, Scotland
    Default Door Pins - Will these fit my car?
    Hello, just wanted to check these would fit my vectra C 2007....
    http://cgi.ebay.co.uk/VAUXHALL-Astra...3286.m14.l1318
    and i just remove the orange part of the original pins and pull them off?
    then these slot on top and tighten with an allen key? that all?
    Thanks,
    Sammy
    Regular Member Robbie69's Avatar
    Should fit no problem mate.
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    oh, yes but I'm sure you can get them cheaper on e-bay
    Dundee, Scotland
    and im right about the fitting? thats all it is lol
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    yes they should fit although you might need to cut the rear ones a little so they all sit at the same level
    lanark
    Year : 2012
    Mileage : 9k
    Quote Originally Posted by sduk View Post
    yep easy as that
    Dundee, Scotland
    sounds ok, just confirm you would hacksaw the new door pins to fit? or trim the part that is in the car?
    lol im a noob at this!
    and the originals just remove once you take the orange part out?
    lanark
    Year : 2012
    Mileage : 9k
    i had to hacksaw the new ones (not the bit in the car) and yes the originals just pull out
    Jun 2007
    in a white box
    The rear "pin" metal thing bends just as it goes out of sight. It you don't cut the pins with a hacksaw they will sit higher than the front one's. They usually made of soft metal so cutting them to sit the same as the front one's is easy.
    Use one of those tiny screwdriver to pull the orange square out and lift off....easy....
    Regular Member chrisk318's Avatar
    Kent/London
    yes really easy. I didn't need to cut mine. Or ones I put on my old Corsa C or Astra G
  1. Door pins
    By SRIRob in forum Styling
    Last Post: 16th January 2010, 23:17
  2. Door pins
    By The-Bandit in forum Parts for sale
    Last Post: 5th May 2008, 10:08
