Results 1 to 10 of 21
Thread: newby with a problem already!!!
    Sussex
    Default newby with a problem already!!!
    hello all!!
    i have a 2.2 SRI direct auto, and ih keeps going into limp home mode!
    i have had it plugged in at the VX garage down the road and they have diagnosed the manifold being at fault with a stuck bit inside it.
    also a fuel rail sensor giving a low reading.
    is the manifold a common problem? can i just squirt some carb cleaner up its hole to free the stuck bit or will i need to buy a whole new one for £500?
    help!!
    cheers,
    CURLY
    Regular Member mushy2007's Avatar
    Liverpool
    Sounds like the same problem I had on my old 2.2 direct, luckily for me it was under warranty.
    They did fix it short term but in the end the whole manifold and a new valve had to go in.
    I may be wrong and another guy offers a bit more help.
    Good luck
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    hi m8 and to vectra-c.........
    hope you get it sorted soon
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    welcome: hope you get sorted real soon
    Nicking Ya Dinner.
    Try cleaning the egr valve and the throttle body, throttle body will be at the end of the black pipe from the air meter/box and sitting on the manifold, clean this right out and also pay attention to the small hose running to it also, this gets gunked up, the egr valve iirc *please correct me* should be somewhere to the right side of the engine as you look at it at about cyl head level.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The joys of having the none direct 2.2.. no swirl valve. VV you can just disconnect the EGR on the 2.2 and just blank in off and hang it off the block. Or pay VX £50 to tech 2 it out, and you are correct about the location. Just hope the low pressure isn't down to the pump or that's in the £1000's, again something the slightly different SE doesn't have to worry about.
    EDIT: sorry, Welcome to the club mate.
    Nicking Ya Dinner.
    Try a new fuel filter as well, if this is blocked up it will cause low pressure.
    Sussex
    excellent, thanks for your help everybody, i'll get my spanners and a big hammer out over the weekend and have a good clean up in the engine bay..
    do the petrol engines have egr valves?
    oh, and where is the engine number?
    cheers again!
    CURLY
    Sussex
    if it was the pump, would it come up on the fault diagnosis thing?
    how come they are so expensive too?
    blimey!!
    CURLY
    Liverpool
    Quote Originally Posted by Curly7 View Post
    cheers again!
    CURLY
    Yep the direct does have a egr which in mine was goosed, the pump went shortly after but you'll know when that goes as the is no power at all.
    The nuggets at VX who replaced the EGR valve also knocked one of the injectors which are a one shot install and waited for three weeks for new ones from the EU.
    Hopefully youve only got the egr problem and mine was a one off dud.
  1. Newby
    By leeibbotson in forum Introduce yourself.
    Last Post: 11th November 2010, 16:21
  2. I everyone, Im another newby....
    By jonski in forum Introduce yourself.
    Last Post: 21st October 2010, 08:09
  3. newby
    By andy22sri in forum Introduce yourself.
    Last Post: 17th May 2010, 08:44
  4. newby with factory lpg fuel gauge problem
    By daryl28 in forum Vectra C / Signum Troubleshooting
    Last Post: 1st December 2009, 23:01
  5. hi, im a newby!
    By big rich in forum Introduce yourself.
    Last Post: 13th November 2008, 17:51
