Thread: engine is idle then speed then idle like its struggling to stay in idle
    aberdeen
    Default engine is idle then speed then idle like its struggling to stay in idle
    ok my 1.8 ls 16valave 03 plate vectra is idleing rather spluttery like itsstruggling to stay idle and drops the revs then speeds up to get bck to idle if that makes sence any ideas?
    Mileage : 000
    Sounds like the Air control valve to me. Might need cleaning with some "carb" spray.
    PS I take it the air filter is clean.
    aberdeen
    air filter is new the censor on top ot the front of theengine looks to go in to a bit of exhaust or somet that was checked and replaced still same were is this other sencore ur on about if its on the plastic where the air filter goes then again changed already .
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Throttle body needs cleaning, it's where the air feed from the airbox finally goes 'into the engine' ie, on the intake manifold. Remove the air pipe and clean inside with a toothbrush and a little petrol and then wipe out with a lint free rag. Open and close the butterfly too and clean it too.
    Jan 2006
    Skynet HQ EMEC#5
    Another thing to check, as I found out yesterday when mine (1.8 / 53 plate) was at the dealers - is the pipe marked wth the circle in the following pictures.
    It only has a small bore & can block up, check pipe & hole in throttle body.
    For anyone that had a cavalier 2.0 ecotec, it's the same thing as that stupid fitting that used to block up under throttle body - cylinder head side.
    HTH
  1. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  2. 1.8 Idle speed
    By cpt slow in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2011, 14:43
  3. Idle Speed?
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 13:29
  4. I need to increase idle speed
    By manimal in forum Engine & Drivetrain
    Last Post: 1st December 2010, 01:07
  5. engine idle speed help
    By jaxouk in forum Engine & Drivetrain
    Last Post: 17th April 2008, 20:57
