Thread: OIL for my 03 2.0 DTI
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Default OIL for my 03 2.0 DTI
    So people!
    If money is no object what oil would be the best to buy?
    I had a service about 3k miles ago (if that) by independant garage and i think the oil is a bit Poo!
    So time for a quick change me thinks...
    Mileage : 000
    If money is no object then. I use Mobil 1 in mine. You would need to get the Deisel "version". But the VX oil is Very good. well worth a look at.
    May 2008
    Widnes.
    Taken form another site!
    Mobil 1 OW-40 Turbo Diesel
    Is the ultimate performance, synthetic engine oil designed to provide unsurpassed protection for the engines of all diesel powered passenger cars, light trucks and vans.
    Offering all the benefits attributable to Mobil 1 0W–40.
    This one then?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Castrol GTD Magnatec, great oil and aint expensive either
    Regular Member WeDesign's Avatar
    Jun 2006
    Vectra-C.com
    Engine : CDTi 150
    Year : 55
    Quote Originally Posted by Ste View Post
    I think you've missed the point he stated "money was no object"
    Regular Member delete2's Avatar
    West Midlands
    Mobil 1 is what i use in mine noticed it run a little less tractor-like. i shoved some slick-50 in there as well and it reduses the clatter alot ive noticed. Slick-50 is about £25 from halfords for 750ml i think, but ve found its well worth it
    Jul 2006
    Buy geniune GM oil from AutoVaux here - £20 for 5L and it's exactly what the engine needs
    May 2008
    Widnes.
    I never new what was good and bad apart from the (IMO) Un Branded oil.
    I am in the thinkin of mobil 1. And mite give that slick-50 a go then to.
    Oil shopping tomorow
    Thanks guys
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Hi...
    I would use the VX oil... albeit mobile 1 is good...
    there is alot of talk about slick 50 and the other additives.. before you do, i would suggest you have a search on here for the up and downs...
    my friendly mechanic says no.. as ptfe is a solid (its in slick 50) and it has to stick some where, oil drains and such like so can cause issues, albeit there are plus points too...
    worth a trawl too get some expert advise first!
    Jul 2006
    I'll be using the genuine stuff for £20 and I've done quite a bit of reading recently about additives - if you do a bit of homework you'll find that while Slick 50 and the like were good 10 or 20 years ago, modern oils are more than enough to lubricate the engine.
    Regular servicing has got to be better than relying on gunk.
what oil for vectra 2.0 dti
