Thread: Wired up my tow bar yesterday
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Default Wired up my tow bar yesterday
    Fitted the towbar a while ago, but never got round to do the electrics.
    Until yesterday, wired it up quite easily. Didn't use VX adaptor or need tec2 or anything else.
    Took the indicators straight from the back of the light clusters on each side (no buzzer as I seem to have 'lost' it - easy to fit when I find it)
    The tail light I took from the number plate lights through a relay to both trailer socket tail lights, there is a connector on the rear bulkhead behind the plastic panel. These number plate lights operate on full 12V and can easily operate a relay as well.
    Stop lights were taken from the high level brake light as it is 12 V - again through a relay.
    The normal tail / stop lights operate on reduced voltage for tail and full 12 V for stop. This proved unsatisfactory to operate a relay.
    Power for relays was taken from the rear fuse board behind left hand side boot panel, justput a spade terminal on the wire and pushed it into a free fuse slot on the power side, put a fuse inline.
    Took a couple of hours to wire up and make good, best of all it cost nothing and I have no bulb failure warning on.
    Works a treat. Who said it couldn't be done ??? and would throw the bulb failure light on? To be sure, I was relieved it all worked properly.
    Dec 2005
    south shields
    thats good advice m8 ive got one of them detachables to fit when the weather gets a little warmer, and i didnt fancy fitting the bypass relay as its got to come from the battery. glad to hear it works with no problems
    Regular Member MrSpike's Avatar
    Devon
    Nice one - I had already figured the eye-level brake light may work but I hadn't thought of using the number plate illumination for the sidelights.. I was going to try playing around trying varios feeds this afternoon although I was worried I might damage something. Now I'm happy I can complete the installation of my towbar. £70 all in, bargain
    Well done Ste, always good when it comes together & cost 'Zero' best of all no error codes or the such ....
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    This thread is 3 years old..... My towbar installation cost me £25 all in, except for a couple of relays I had lying around
  1. pre wired ?
    By veclee in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2012, 13:17
  2. pre wired
    By wullie-t27 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2012, 20:36
  3. Where is your wiring kit wired through??
    By adzs22 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2010, 10:54
  4. Wired up 2nd foglight
    By winnie2457 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2010, 20:27
  5. Wired FM Modulators
    By Cerealuk in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 20:04
