Results 1 to 10 of 27
Thread: t c switch
    Regular Member DARREN R's Avatar
    Jan 2008
    WASHINGTON
    Vehicle : vectra
    Trim : sri xp
    Engine : z19dth
    Mileage : 93000
    Default t c switch
    if i take out the blanking cover where the traction control switch should be on my 06 sri cdti and there is a blue plug to put the switch into does that mean it would work with the switch or would it have to go to dealer to be programmed ??? and does anyone have any idea how much the switch would be ???
    Switch is around a tenner - part number in the part number section.
    If you have the blue plug then it will light up the switch. It's 50/50 whether it will then actually turn off the TC or not - you simply have to try it. No Tech 2 needed.
    Regular Member B19CBB's Avatar
    Nov 2007
    North East
    Vehicle : Insignia
    Trim : Sri Nav VxLine
    Engine : 2.0 CDTI 160 ps
    Year : 2011
    Darren, I've got a tc switch you can try, i bought it for mine but it dont work for me, i live at Heworth send a PM if you want to give it a go,
    Regular Member sduk's Avatar
    Dundee, Scotland
    sorry to digress but how does the switch remove?
    Jul 2006
    Mexico
    you pull it out
    11 Post(s)
    Does your car actually have TC?
    By fitting a switch to a car that hasn't - won't magically add TC to the car.
    Here, there and every where!
    The switch only turns the traction control OFF!!!!! It doesn't do anything else
    Good point. I hadn't noticed/clicked it was a 2006 model before answering. It may not even have TC fitted, although why would it have the blue plug even there if 2006 models didn't have TC? Very odd! lol
    Dundee, Scotland
    is the best way to remove the blanking plate just to wedge it out with a flatheaded screwdriver?
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Yes. Unless you specify ESP, or ESP comes as standard (V6 models only) you won't have TC to switch. TC on all facelifts (except some early ones which were not 1.8 petrols) only comes as part of the ESP option.
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  4. t/c switch help
    By kitchcav in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:02
