Results 1 to 10 of 14
Thread: Replacing foglight bulb
    Regular Member andy13's Avatar
    Default Replacing foglight bulb
    Is it possible to replace the foglight bulbs on a pre-facelift without having to remove the front bumper. If it is how do you do it?
    scotland
    yes , look undrneath them there is a disc that spins off the underside of the unit ,
    then unclip the bulb , remove the wire and replace all bits in reverse
    Tried looking underneath them but there is no access to either fog light. Help!!!!
    Mileage : 000
    Where are you looking then? There is as gxrster says underneath the front bumper ( on the flat side) there is a large black "bung" it is about 60m/m dia. turn it and it should come off, you will be able to see the wires for the bulb then.
    Regular Member Daywalker's Avatar
    Aug 2007
    Kaunas raj
    Vehicle : Qashqai
    Trim : Visia
    Engine : 1.5dci
    Year : 2010
    Quote Originally Posted by gsxrster View Post
    Had my brake pads replaced today so i asked my mechanic to have a look at replacing the bulbs and he had to remove the leading edge of the underfloor tray just to get any access to it
    scotland
    that woulda taken 2 mins mate
    its on wi clips IICRC
    2 mins if i had any sort of equipment!!!!
    Regular Member vectragsi3.2's Avatar
    Feb 2007
    cheshire/staffordshire
    as mine is lowered i have to jack the car up and as everyone has said there should be nothing restricting you get to the fog light apart from a cover what you screw off undo the clip take the bulb out and replace its that simple!
    scotland
    Quote Originally Posted by andy13 View Post
    have you even looked ????????????
  1. vxr foglight bulb type please
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 24th April 2012, 22:57
  2. Facelift Foglight Bulb change
    By Coggy69 in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2011, 17:43
  3. foglight bulb replacement
    By aerodynamic18 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2009, 18:37
  4. SRi Foglight bulb?
    By jamesr in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2006, 02:02
  5. Signum FogLight Bulb Replacement
    By sjanisz in forum Electrical & ICE (including SatNav)
    Last Post: 22nd June 2006, 15:43
