Thread: Help
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Help
    Please Help Just Got In The Car After Work And When I Turned The Ignition On A Car With The Spanner Light Came On And When I Tried To Start It It Wouldnt Start. It Started On The 2nd Attempt And The Spanner Light Didnt Come On However It Has Lost Loads Of Power And When I Put My Foot Down It Takes Ages Through The Revs And Wont Go Above 4000 Rpm Its A 1.8 Z18xe Sxi 41000 On The Clock Also Have Emission Light On Aswell
    Administrator plasma's Avatar
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    sounds something it quite wrong with the emissions side of things need to get to a garage asap
    SAUCHIE
    It sounds like your car has gone into limp home mode which is usually started by the ECU due to a fault with the emission side of things. It needs to be put on the laptop.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    cheers guys took it too the dealers and booked it for friday this is the 4th time now so i said i want a tech test free as they keep telling me all is ok. today it has been sweet as a nut still quite slugish but im putting it down to as im used to it i also put my sports panel filter back on and took the piper cross cone filter off drive better ive noticed
