Results 1 to 10 of 11
Thread: Loose rear end...WHY?
    Jul 2006
    Mexico
    confused Loose rear end...WHY?
    After my brake pad change (front and rear) and my disks been rectified, I feel that the rear end of the car is loose on curves now....before the brake service the car felt that rolled on tracks (if you know what I mean).
    I asked the chap that did the service to rotate my tyres...left front to back right an so....
    NCT´s do no t have a rotation preference that I know off....any ideas why it is loose now?
    Any comments welcomed
    Jul 2006
    Mexico
    UPS! sorry Admin double post,,please delete, erase, kill, vanish this one
    Firstly check the tyre pressures if they are ok i would suspect the rear dampers are shot my 3.2 tried to swap ends on me every time i went round a corner quickly till i swapped the dampers for some new ones !!!!!
    Jul 2006
    Mexico
    Quote Originally Posted by Drinky View Post
    Tyre pressueres are OK....dampers? sorry about my english but dampers are shocks? or the coils or a different ball?
    South east
    Dampers are the shocks... they "damp" i.e. reduce the up and down movement of the springs (springs=coils)
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Check your rear suspension arms. While the car is on the ground, grab the rear wheel with both hands (hands under the arch grabbing hold of the back of the tyre) in the 12 o'clock postion and try and pull towards you then push away from you. If there is any movement that would help explain your loose back end.
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I have a loose backend hmmmm that sounds a bit rude
    Jul 2006
    Mexico
    Quote Originally Posted by Rebellion View Post
    Gotcha! thanks
    Quote Originally Posted by merikiito View Post
    I´ll try that mate and see what what happens
    Jul 2006
    Mexico
    On the other hand I was thinking that is to much coinsidence that after the brake service the shocks fail....bad luck maybe
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Heres how to check your rear suspension arms.....
    http://uk.youtube.com/watch?v=h-LF-qQY-Lc
  1. Loose Rear End...
    By dunc2610 in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2011, 22:52
  2. my rear feels loose
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 28th May 2011, 16:18
  3. Loose rear end...WHY?
    By BlueRob in forum Suspension, Wheels & Brakes
    Last Post: 29th July 2008, 18:33
  4. Rear bumper loose?
    By peter142 in forum Bodywork & Interior
    Last Post: 2nd October 2007, 20:20
  5. loose rear end?
    By JonR in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2007, 12:09
https:www.vectra-c.comforumshowthread.php54345-Loose-rear-end-WHY
