Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: Wheel wobble at 40 to 50 mph
    Durham
    Default Wheel wobble at 40 to 50 mph
    I have just bought an 03 plate 2.0 DTI with 107K on the clock, it has what can be described as a slight wobbly feel on the steering wheel at around 40 to 50 mph, feels smoother at 55 mph but is still detectable(keeping below 60 mph) until I get it sorted out, does any one have a step by step plan as to which bits I should change / check in what order to sort it out ?
    It also has a clunk from the NSF when going over speed bumps, also who is best for buying Track rod arms / drop links wishbone bushes etc.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well you could have several problems,
    Warped wheel (are they alloys? Any damage?) but normally they will vibrate at all speeds.
    Wheels need balancing (try this one first)
    Front bearings (check movement with wheel off the ground)
    Front dampers (check for oil leaks with wheel off and bounce the car while it is on the ground, it should not bounce more than once I think and should be reasonable stiff)
    Broken front spring (remove wheel to check)
    Track rod ends (check for lack of movement while car is on the ground and you move the steering wheel)
    Get a haynes manual as this is a great help and £17 well spent
    Durham
    Yes they are alloys, cheers I will start of with simple checks.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The wobble is almost definitely balancing, mine was exactly the same (03 2.2 SXi), I booked it in for a full four wheel alignment, but the guy re-balanced all the wheels, said "that was probably it, go try it before we do the alignment and charge you a fortune" and he was right. Cleared it straight away.
    Definitley get the wheels re-balanced before spending out on anything more expensive.
    The clunking could be any number of things though although drop links would be my first suspect closely followed by broken spring.
    Surrey
    I am sure it is a balance weight that has come off.
    As for the knock, does it sound like something loose if so could be anti roll bar bushes.
    Durham
    Thanks for the advice, will start off checking wheel balance, then see if what I have done makes any difference.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    as been said above m8 as the wheel balancing normaly startes at about 60/70 + mph so it could always be a tyre out of shape as this WILL start at low speeds HTH m8
    Durham
    The local tyre place will check the wheels and tyres out, will report back the findings.
    Quote Originally Posted by iwoo View Post
    good luck buddy
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Definately sounds like wheel balancing.
    It solved it on mine, until it started doing it again, so I checked the tyre pressures and they were absolutely all over the place, once I set these to what they should be (I think 33-36 on front and 36 on back-or something there abouts), it was right as rain.
    I was surprised that the tyre pressures could have such an effect on the drive of the car.
    Set the pressures then get the balance done.
    You should be OK.
    As for clunk, as I have read on this site, could most probably be your drop links.....but go with what "merikiito" has said and do the other checks too!
    HTH and happy motoring mate!
  1. Wheel Wobble - What next?
    By logi6260 in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2011, 16:13
  2. steering wheel wobble
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 22:44
  3. Wheel wobble
    By signumboy in forum Handling & Braking
    Last Post: 2nd November 2010, 16:25
  4. Wheel Wobble
    By rsocon in forum Suspension, Wheels & Brakes
    Last Post: 17th June 2010, 14:15
  5. Wheel wobble
    By raymie.d in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2007, 16:09
vectra dti wheel wobble at 55 mph
