Results 1 to 10 of 16
Thread: vectra c wheel bearing noises
    kent
    StatsVehicle Info
    Talking vectra c wheel bearing noises
    hi all i have a vectra c on a 2003 18 ls petrol,i fault i had a wheel bearing problem,change the front and still the widing was there ,so i brought a back bearing ,,and guess what still there ,i change them all around ,and still there ,the sound is coming from the back and now its doing my jead in ,what can this be i spent about £220 on bearings for nothing,also i noticed on the back wheels when you give them a tug both sides have movment by about a half inch or so ,is this normal, please help ,it doing my head in now,also it should be the 120bhp, goes like about 80 bhp ,why is this just seems lazy,,,,think that will do for now ,,thanks
    Regular Member aaruck's Avatar
    Cheshire
    StatsVehicle Info
    If the bearings are ok the wheels shouldnt move at all I thought?
    Cheshire
    StatsVehicle Info
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    StatsVehicle Info
    hope you get it sorted out m8
    and to vectra-c.......
    Jul 2006
    StatsVehicle Info
    Really difficult to read your post
    What tyres have you got fitted? Bridgestones are notoriously noisy. If changng the wheel bearings hasn't fixed the problem I'd start looking at the tyres
    Birmingham
    StatsVehicle Info
    Quote Originally Posted by bobbyb768 View Post
    First of all to the site buddy!
    Secondly, from reading your post I noticed you mention something about your back wheels have play in them when you tug at them....is this correct?
    If so, the lads on here identified for me that if the movement is present, then it is the rear upper control arms (banana's)!
    Have a look at the links below, its long but identifies the problem, could be whats happeneing with yours.
    Hope this helps and hope you get the problem sorted soon mate with minimal £££££££'s!!
    READ THIS THREAD....LINK FOR REAR CONTROL ARMS CHECKING
    READ THIS FOR THE AFTERMATH OF CHANGING THE CONTROL ARMS
    Bye bye Vec B
    - Hello Siggy!
    Sunny Dartmoor
    StatsVehicle Info
    Hope you get your problem sorted m8.........
    Full Member Jay Kay 313's Avatar
    Burgess Hill
    StatsVehicle Info
    and enjoy
    Astra Estate SRi XP 1.7 CDTi 100
    Regular Member ion's Avatar
    walsall
    StatsVehicle Info
    As above play in the wheels is not normal mate.
    kent
    StatsVehicle Info
    Quote Originally Posted by aaruck View Post
    thanks for the help ,i will change the rear bushes ,and upper arms ,,
  1. HELP PLEASE which wheel bearing, with IDS or not ?
    By armoured farmer in forum Troubleshooting
    Last Post: 13th October 2011, 17:27
  2. Please help wheel noises
    By ONEMINUTESILENCE in forum Suspension, Wheels & Brakes
    Last Post: 18th January 2011, 21:24
  3. Wheel Bearing?
    By markdowl in forum Suspension, Wheels & Brakes
    Last Post: 31st August 2010, 23:36
vectra 2003 how can you tell if bearings are going
wheel bearing vectra c
vectra c wheel.bearing
change rear wheel bearing vectra c
