Results 1 to 10 of 20
Thread: Heaters only blowing hot air??
    Apr 2008
    Merseyside
    Vehicle : Vauxhall Vectra
    Engine : 1.9 cdti
    Default Heaters only blowing hot air??
    Hi, I have a 2L DTI 2004 Vectra and im only getting hot air when i turn my blowers on and the dial is turned to cold(blue). Can anybody help? Thanks
    Apr 2008
    Merseyside
    Engine : 1.9 cdti
    anyone?
    Regular Member Leviathan's Avatar
    Middlesbrough, Cleveland
    Hmmm, could be a few things - I am no expert though:
    Heater matrix
    Broken Dial or linkage
    Head Gasket?
    Is there any damp/fluid in the front footwells?
    Whats the water level/coolant level like?
    SAUCHIE
    Hi Mate. On the hot water supply to heater matrix there is an electronic valve that shuts the water supply off to the matrix which then lets it cool down and in turn blows cold air. It sounds like this valve is not closing due to a fault with the valve or the signal getting to it from the heater control switch.
    Apr 2008
    Merseyside
    Engine : 1.9 cdti
    thanks, were bouts is this located? Thanks
    Apr 2008
    Merseyside
    Engine : 1.9 cdti
    think iv found the problem after taking the time to search the forum, iv taken the govle box out and when i turn the dial the red lever isnt moving, i removed the red lever and turned it with a screw driver and the cold air is coming through. having reconnected it its still not moving. Does this mean theres a faul;t in the actual control panel of the blowers? Any help is much appreciated. Thanks
    SAUCHIE
    if you have a multi meter and you know how to use it then test the power supply to the water control valve and also the control switch. Also have a look at fuses but I would be more inclined to fault the valve than anything else.
    Apr 2008
    Merseyside
    Engine : 1.9 cdti
    Thanks, can you point me in the direction as to were the valve is? Thanks
    SAUCHIE
    The servo is the thing in the glove box that you moved manually. The arm moving up and down either opens or closes the water control valve. This valve is opened or closed with the servo which is attached to the said arm you moved. It is held in with 2 screws and a connecting rod. Remove the 2 screws, the connecting rod and the connecting power block and remove for testing. Test the connecting wires to see if there is a live feed to the servo. Also if you know how to or know someone who can use a multimeter then test the resistance of the servo and also the output from the power supply. Hope this helps
    Brough, East Yorks
    Smile
    Just had this same problem, removed glove box and found red leaver not moving when temp control dial turned, bought new unit and fitted, worked a treat, Out of curiosity stripped old unit down (can be done by carefully prising up small clips) removed plastic gears and prised out motor unit and plug housing , to find small set of pickup contacts on the reverse side of the larger gear, cleaned them up with a clean cloth and then rebuilt the unit and tried it by plugging it back in and hey presto it works.
    Moral of tale : make sure it is broke before you by a new one.
  1. no heaters on car
    By tash in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2012, 12:20
  2. heaters not blowing hot.
    By Jaspa in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd June 2012, 22:45
  3. Heaters
    By Bazz in forum Bodywork & Interior
    Last Post: 2nd December 2011, 23:45
  4. Vectra 2.2 elite 2003 heaters not blowing
    By vectracraig in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2011, 03:23
  5. heaters not blowing cold
    By andyman201 in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2010, 18:29
vauxhall heater only blowing warm air www.vectra-c.com
my cdti vectra only blows hot air
vauxhall insignia blowing hot air
