Results 1 to 10 of 19
Thread: does my car have a problem....?
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default does my car have a problem....?
    finished work today, got in the car and it was reading 31 deg C.
    straight after starting the car I turned the air con on and it caused the car to run really lumpy.
    turn the air con off, back to normal, back on lumpy.....??
    it only felt lumpy on idle.
    after the trip, i sat on the drive and it wasn't doing it anymore....
    is it:
    1. a problem
    2. going to be a problem
    3. you have a vectra get used to it...........
    Regular Member mat osborn's Avatar
    Jan 2008
    leicester
    mine does the same when ac compressor kicks it causes revs to drop slightly
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    As above. Mine runs noticably less smoother with the AC on (as did the other 2)
    I'll go for no. 3 - seems to be the norm i'm afraid.
    Apr 2008
    middlesbrough
    yes mine to although it need a re-gas so not using it at the moment
    Regular Member Vauxhall Thru & Thru's Avatar
    May 2008
    Nottingham
    I think it's probably normal. The AC is an additional power off-take from the engine; the ECU probably invokes a different fuel schedule when AC is on to take account of the extra load. Hence the revs blip, and the lumpiness. Just my thoughts, may be completely wrong!
    Suffolk
    i know it runs lumper (is that a word lol) but this was more than usual.
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    mine feels like it wants to almost stall with the aircon on at idle! but is normal
    May 2007
    South Oxfordshire
    I've found consistently over 2 years, that my 3.0 CDTI's electronics raise the engine idle speed a bit at exactly 25 degrees and above, with the A/C on. As soon as the outside temp drops below 25, things return to normal. Also (of course) the idle fuel consumption goes up from 0,3 g/hr to 0.4 g/hr.
    I have the air conditioning on at all times
    There is no difference in revs, whether the engine is cold or warm
    Presumably the 3.0 V6 CDTI ECU recognises that the air conditioning is on so maintains the same idle revs
    In previous cars with air conditioning the revs normally increase slightly when the engine is cold
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    The ECU should compensate for the air con being ON, revs should be very slightly higher than normal when cold.
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
