Thread: vx changed me egr valve all good but..
    Mar 2007
    Hull
    Default vx changed me egr valve all good but..
    what exactly does it do? iv had a search on here but no real description.
    cars off like a rocket now tho well happy, and all under warranty
    thanks all
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    why did they do it did sumit else go wrong coz i heard off avaux mech when they do inlet manifold or whatevre egr valve goes after it
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Quote Originally Posted by robhullfury View Post
    thanks all
    Exhaust,Gas,Recirculation. As it suggests, its a method for recycling gases from the exhaust back into the intake, which if working properly will reduce emissions and increase fuel economy.
    However if EGR is on during idle, roughness, and even stalling will likely result. If EGR is on during hard acceleration, low power (from reduced air/fuel volume) is the result. At part load, lean mixtures for economy create high combustion chamber temperatures and without EGR, these conditions not only create Nox, they also foster pre-ignition and pinking, so when working 100% it does its job well, but like most things in life the more complex things become, there's more to go wrong. It would seem VX has had reliability issues with many of the EGR valves, I believe it may have been improved on new versions of the valve.
    I recently took my car in for its 30k oil/filter change (I like to change it every 10k) and asked them to check it out for possible reduced power and not running as well as it used to. Despite the fact I had not had the spanner light (limp mode) come on at all, they replaced the EGR valve under warranty so pehaps something had shown up when tech2 checks were made.
    Mar 2007
    Hull
    cool, willoftoon the only work iv hard doen recently is the alternator which very inconviently went in rush hour traffic when I happen to stall at some traffic lights. buggar!
    cameron43, i had a problem the other night with a lack of power the turbo had also stopped working by the feel of the car. stupid thing, all good now tho seems to fly.
    thanks for the info tho!
    rob
  1. Replies: 6
    Last Post: 29th July 2012, 13:52
  2. CIM CHANGED NEED TECH2 in OXFORD AREA HAS ANYONE CHANGED A CIM BEFORE?
    By vectrasimonsri in forum Electrical & ICE (including SatNav)
    Last Post: 10th July 2011, 20:43
  3. Liqui Moly Diesel Throttle Valve Cleaner - Any Good???
    By hotrod09 in forum Engine & Drivetrain
    Last Post: 10th October 2010, 15:48
  4. Good job i changed them really!!!
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2009, 18:37
  5. Egr valve changed today still has problems !!!!
    By andymcniven in forum Engine & Drivetrain
    Last Post: 4th April 2008, 18:33
