Results 1 to 10 of 29
Thread: 1.8 Idle speed
    Regular Member cpt slow's Avatar
    In a house
    Default 1.8 Idle speed
    Is my idle speed to low I ask myself , can it be adjusted to idle slightly higher as it sounds a bit strange . On the rev counter it sits on idle just above 500, its allways done this but now just doesnt seem right . Can it be adjusted to idle higher ? Is this controlled from the ECU ?
    In a house
    no one ? where are all the 1.8 owners !
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Not a 1.8 owner but would say it's a bit low,their normally up around 750/800
    Think it can be changed but guess it would a special tool job.....
    don't tell me the stig drives a vectra!
    In a house
    Can anyone please tell me if the idle can be adjusted to a higher RPM , is this Vauxhall only job ?
    you could try giving your local Vx dealer a call if you aren't getting much luck here...
    g
    In a house
    Looks like I will have to tomorrow . I know there are a few 1.8 owners here , but obviously are not online or keeping it a secret ! Cheers.
    Im sure its a vx job mate, mine ran @550rpm and they turned it up to 650rpm, gave the tech a tenner, not worth booking in ,just popped down .2 min job.
    Quote Originally Posted by caprimanuk
    Patience is a virtue ... Someone will answer you question, might take more than a few hours though mate ...
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    just come on line mate my 1.8 sits about 800rpm once heated up so i would 500 is a bit low is it easy to stall then
  1. High idle speed
    By 19CDTi in forum Engine & Drivetrain
    Last Post: 1st July 2012, 11:02
  2. Idle Speed?
    By Badger59 in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2010, 13:29
  3. 2.2 (Z22SE) idle speed
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2009, 08:50
  4. ajusting idle speed
    By Morephun in forum Petrol Engine related
    Last Post: 17th February 2009, 19:36
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
idling speed for a vauxhall 1.8 insignia
vectra c 1.8 idle speed
