Results 1 to 10 of 20
Thread: Knocking Noise from Suspension
    South east
    Default Knocking Noise from Suspension
    Have had the anti-roll bar links replaced all round, to cure the clunking noise. The garage admitted before they did it that this was a first step; the noise is much less frequent now and no longer seems to be caused by vertical movement of the suspension, but there is an occasional knock from the front when turning the wheels at low speed....anyone have a good idea of what could need replacing next? Please don't everyone just list every suspension component they happen to know the name of though...lol.
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    is it one of the shocks ? as long as the rack is ok it should not be expensive!
    South east
    Quote Originally Posted by moorlander View Post
    All the components have been checked visually by the garage whilst up on a ramp, no problems visible, including shocks. They changed the drop links as that's the most common cause, not because they looked like they needed it.
    Jul 2006
    Quote Originally Posted by Rebellion View Post
    That's my best guess out of the window then
    Is it definitely suspension noise? I recall some members a while back had issues with radiator mounts causing a knocking noise....
    South east
    Def suspension....same noise as faulty drop links cause, just much less frequent now and no longer caused by speed bumps.
    Jul 2006
    Have you checked your bowl-cereal interface?
    South east
    Quote Originally Posted by parapaul View Post
    Absolutely no idea what you could possibly be referring to. lol
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Bit of a long shot....but are you sure its not the exhaust?? Worn bush's may be causing it to hit the body? Sometimes its what you least suspect? Worth a try!!
    Right the most common "knocks" from the front are
    Drop links (Done)
    radiator mounts (can sound like suspension )
    front anti roll bar bushes
    but my favourite guess would be the front spring seat mods (if these were done a while ago they may need doing again as they do wear through )
    If the steering feels fine then i doubt it would be any thing to do with the steering rack ( although we do know they eat through the steering arms )
    Apr 2008
    Staffordshire
    Quote Originally Posted by vauxmang View Post
    I know what you mean, everytime I turned right on one of my old cars I got a metallic dull thud...after 1/2hr of looking with a torch on a winters nite I found a piece of metal - like a metal hockey puck - not from the car!
  1. Vectra C, 2002, Rear Suspension knocking/creeking noise
    By richardkay007 in forum Suspension, Wheels & Brakes
    Last Post: 11th May 2012, 19:05
  2. Knocking/Clunking noise from front suspension
    By MrDerv in forum Suspension, Wheels & Brakes
    Last Post: 21st April 2012, 17:14
  3. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  4. Rear suspension knocking noise, help
    By clive3373 in forum General Chat
    Last Post: 8th May 2009, 20:24
  5. Suspension change - now a knocking noise
    Last Post: 5th November 2008, 21:12
