Results 1 to 10 of 24
Thread: Wheel Alignment?
    Jul 2006
    Question Wheel Alignment?
    I know what the answer to this question should be - just wondered what everyone else's opinion is?...
    I need 4 wheel alignment because the tracking was out anyway, and I've just had the suspension lowered.
    I've been to www.alignmycar.co.uk - the closest place with Hunter equipment is 26 miles away and will charge upwards of £60-80 depending how much adjustment is needed.
    The local Kwik Fit will charge upwards of £55, again depending how much adjustment is needed.
    The local independent (read back-street) tyre place charges £50.
    I know I really should go for the Hunter-equipped place, but it's about a 45 minute drive each way... What would you do?
    Here, there and every where!
    Hunter m8. I would anyway
    Feb 2007
    Glasgow
    My nearest is 26.26 miles. I made the trip
    Jul 2006
    I knew you'd say that....
    The place is called QR Sport in Tattenhall... Anyone heard of them?
    Quote Originally Posted by parapaul View Post
    Drinky!!!!!!!!!!!!!!!!!!!!!!!
    Birmingham
    If you are ever down in Brum, got to the place I use, "tyre R us", max charge you will get is £40.00 for a 4-wheel alignment.
    If there is only front wheel alignment required, may well be just £20-25, and it is all done on a computer with laser beams and what not!!
    I use this guy (ANDY) all the time for all of my car(s) and he is top notch!
    Give him a call....google "Tyres R Us", in Witton - Birmingham.
    HTH.
    Bye bye Vec B
    - Hello Siggy!
    Jul 2006
    Work this out if you can...
    Just called both my local Vx dealers, double checked with each one that it was 4 wheel alignment they were quoting for, but they both came back with
    £27.95
    Now, I suspect the girls on the phone didn't actually know what I was asking for, and they've probably quoted for bog standard front wheel setup, but it's strange that they both got it wrong, and both gave exactly the same price?
    Feb 2007
    Glasgow
    Not sure they all understand what you want. I got mine done when I got the exhaust at MIJ, but they didn't adjust the rear camber, although it was still a 4 wheel alignment.
    Probably worth clarifying what you get. I was impressed with the whole Hunter thing, you get a full suspension check first, as they won't align it if anything is worn (this might vary depending on where you go).
    Pretty printout of the before and after too
    Birmingham
    £27.95
    That is weird, something deffo not right there, probably quoted you for balancing. Vx prices for balancing at £27.95 wouldnt surprise me!!
    Bye bye Vec B
    - Hello Siggy!
    Jul 2006
    possibly! But like I said, I double checked with both of them that it was definitely 4 wheel alignment...
  1. 4 wheel alignment
    By tangoman in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2012, 21:42
  2. wheel alignment
    By matt2005 in forum Suspension, Wheels & Brakes
    Last Post: 8th March 2012, 12:32
  3. 4 Wheel Alignment
    By Tam80 in forum Suspension, Wheels & Brakes
    Last Post: 29th January 2011, 20:06
  4. 4 wheel alignment
    By dave_taiho in forum Northern Ireland (RO - Vacant)
    Last Post: 9th March 2010, 16:35
  5. 4 wheel alignment for £40....
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2008, 22:40
