Results 1 to 3 of 3
Thread: pulley replacement
    EDINBURGH
    Default pulley replacement
    anyone got any tips for replacing crankshaft pulley on my 2003 DTI, seems to be a special tool for holding crank shaft is it required?
    kenny
    Feb 2006
    Guttedsville
    Honest answer, unless you have access to a windy gun and a torque multiplier, you'll be better off biting the bullet and sending it to a garage, they are stupidly tight, you'll need a new bolt too.
    Mar 2007
    dublin
    I had the same problem a while ago, go to a truck tyre repair centre and get them to loosen it with one of their guns, nothing else will shift em
  1. Alternator pulley - replacement has finally arrived
    By Caveman_nige in forum Engine & Drivetrain
    Last Post: 1st September 2012, 18:23
  2. Timing Belt Replacement -Crank pulley removal
    By alcutler in forum Engine & Drivetrain
    Last Post: 4th April 2012, 19:44
  3. Crankshaft pulley replacement
    By Croxley in forum Engine & Drivetrain
    Last Post: 25th May 2011, 08:35
  4. Aux/Drive belt tensioner & pulley replacement
    By Marky in forum Engine & Drivetrain
    Last Post: 5th October 2010, 20:43
