Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: engine shutdown
  1. #11
    Hertfordshire
    Hose 1 is turbo to intercooler and is the most common failure.
    Hose 2 is intercooler to throttle housing (such as it is).
    Vac pipes are also a common failure, and well worth checking to, but these usually give a more permanent limp mode or even a non starter, and the fault is not likely to clear on a restart.
    As I said above, for limp mode under load. boost hoses and boost pressure sensor are favourites.
  2. #12
    beverely
    Hi there
    Thanks for all that info checked the 2 tubo pipes they were ok 2 of the small vacuum connectors were split so changed them took of the sensor off very carefully and soaked in carb cleaner, put back onto car, road tested and it ran absolutley perfect,so connected caravan and went for a good drive and the problem has gone.
    The car has plenty of power
    SO ONCE AGAIN THANKS FOR YOUR ADVICE IT IS MUCH APPRECIATED
    BOB
  3. #13
    Hertfordshire
    Excellent news m8.
  4. #14
    Apr 2008
    CO DURHAM
    can you tell me if you found the problem as mine is doing the same only when towing done everything possible and still doing the limp mode thing
  5. #15
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    Quote Originally Posted by buggy_666 View Post
    have ya tried what i mentioned in your other post m8
  1. Vectra C Total Shutdown!
    By Littleted in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2011, 23:39
  2. squeek on startup and shutdown
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 8th September 2011, 15:08
  3. Forum shutdown for a short while this evening
    By Duncan in forum Site updates etc.
    Last Post: 22nd June 2009, 23:30
