Results 1 to 10 of 15
Thread: engine shutdown
    beverely
    Default engine shutdown
    Hi
    can anyone help please my 2.2dti Signum has started going into shutdown mode when on a journey.
    If you turn the engine off leave it for a couple of minutes then restart it everything is ok
    This happened 4 times today when my Daughter was towing my caravan on a journey of 150 miles
    this has never happened before and has happily towed my caravan ,touring the continent and uk over the past 3 years
    any ideas please
    bob
    Full Member Big Sig's Avatar
    Hmmm, first thing I would check for would be a split in a boost hose. Quite common really, after that, get the fault codes read to get a better idea of whats happening.
    Hertfordshire
    As above check the boost hoses first.
    Second, clean the boost pressure sensor, if it gets gunged up, then dropping into limp mode under load is a classic sign.
    If you do it yourself, and it is easy enough, just be careful, they are very fragile, use a carb cleaning spray, and if necessary soak it, DONT apply direct pressure to it.
    beverely
    Hi
    thanks for that info very interesting as soon as the car comes back I shall have a look at that sensor if I can find it and give a soaking
    bob
    Feb 2006
    Guttedsville
    There she be, in the circle, be gentle with it though.
    beverely
    Hi
    that is absolutely super thanks again for that
    bob
    beverely
    Hi
    sorry to appear thick but when you say check the boost hoses first is that the small thin pipe that must be something to do with vacum that goes to the units at the front of the bulkhead
    bob
    The boost hoses are the ones from the turbo etc. They will be about 2" in diameter.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    the big black pipe at the bottom in the above pic
    Portadown, N.I.
    Quote Originally Posted by robbie1944 View Post
    Hi
    bob
    While you are checking the boost hoses, check to make sure all those little black or white thin (about 5mm thick) pipes are connected ok, and that the rubber connectors are not split( very common ) or loose. These are the vacuum pipes and can cause the EML to light and also cause a loss of power even without lighting the EML.
    Tim
  1. Vectra C Total Shutdown!
    By Littleted in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2011, 23:39
  2. squeek on startup and shutdown
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 8th September 2011, 15:08
  3. Forum shutdown for a short while this evening
    By Duncan in forum Site updates etc.
    Last Post: 22nd June 2009, 23:30
