Thread: signum seat belt removal
    Birmingham
    Default signum seat belt removal
    hi..how do i remove the rear outer seat belts ..its a bit of a mystery to me..can anyone help..
    Regular Member shan's Avatar
    Slide the seat all the way forward and at the bottom of the seatbelt it's bolted to the base of the seat. It's a Torx bolt but i'm not sure of the size.
    If you are removeing the seat don't forget their is a airbag plug under the seat to disconect.
    11 Post(s)
    Quote Originally Posted by shan View Post
    No airbags in the rear seats.
    Birmingham
    signum rear seat belt removal ..its the belt holder i am trying to remove..i cant get the panel off.i undo the two screws but it wont prise off..thanks for answering..
    No but the seats have airbag sensor's. I presume if nobody is sitting in the seat the side curtain airbag will not active.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    no airbag sensors, but seat belt tensioners -or how do you call them?- and active headrests;
    there is only one side curtain airbag that covers the whole side
    I had the plug disconnected and it showed the airbag light on the dash.
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    The 'airbag light' also illuminates if something is wrong with the belt tensioners;
    Control indicator v for belt tensioners
    The belt tensioners are electronically
    monitored together with the airbag
    systems and the operation thereof is
    indicated on the instrument panel by the
    control indicators v. When the ignition is
    switched on, the control indicators
    illuminate for ap prox. 4 seconds. If they do
    not illuminate, or they do not go off within
    4 seconds, or illuminate whilst driving, there
    is a fault in the belt tensioner system or the
    airbag systems – see page 107.
    11 Post(s)
    Quote Originally Posted by sig63 View Post
    I thought the belt tensioners and active headrests were for the front seats only? Unless the Signum has them fitted, but the Verta doesn't to the rears?
    Belgium
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    you are right: the Signum has them on the 2 rear seats, the Vectra not
  1. Rear Seat Belt Removal - Vectra C
    By tutfut01 in forum Bodywork & Interior
    Last Post: 16th September 2010, 10:28
  2. Signum rear seat removal
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2008, 21:41
  3. Front seat belt removal
    By kel123 in forum Bodywork & Interior
    Last Post: 11th July 2007, 17:10
  4. Rear seat belt removal
    By monkeybusiness in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2006, 15:16
