Thread: Drilled Discs
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Drilled Discs
    Any drilled their own discs? It was mentioned in the pub at lunch today and was wondering if anyone has done it and did it have much benefit?
    norn iron
    had a mate do this. dunno about benifit but they certainly looked the part
    Jul 2006
    Northampton
    Trim : Sri
    Interesting... How did he do it?
    EDIT: By this i mean how did he do it not to crack the disc
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Trouble with drilled Discs is Cracking,(Just to make clear, I mean Drilling all the way through as Per Drinky) Not during the process of drilling but with Heat & age. The benifits of drilled discs is the removal of dust etc off the Pads making them bite better & cooling..
    Oh yes & the Looks..
    Ebc used to sell drilled disc's but now sell Spotted due to cracking.
    Spot drilled discs look & work just as good & don't crack
    Dean
    I have been drilling my own discs for over ten years and touch wood never had a problem with them the trick is to NOT drill them right through and yes it does make a difference !!!!!!
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by DeanF View Post
    Dean
    I thought drilled was to help get rid of hot gasses so the pad doesn't "float", and grooved did the same but also cleaned the pad face?
    Jul 2006
    Northampton
    Trim : Sri
    Quote Originally Posted by Drinky View Post
    Mmm... this sounds interesting. can you give me some details on this and a pic if you have one? Have you done like a spotted one or have actual holes through the disc?
    Jul 2006
    Quote Originally Posted by Mugualigwian View Post
    The answer's in his post m8
    I looked into this quite a lot, but from what I read it's possible that dimples will eventually cause uneven wear on the brake pads.
    Jul 2006
    Northampton
    Trim : Sri
    that was a bit silly of me lol. Right, when my brakes need changing i think im going to give this a go!
  1. Drilled and grooved discs
    By sla002 in forum Vectra C / Signum Car Chat
    Last Post: 15th September 2011, 20:27
  2. Drilled and grooved front discs
    By soulie in forum Suspension, Wheels & Brakes
    Last Post: 23rd January 2010, 20:53
  3. Can i get Front Drilled and Grooved Discs
    By armoured farmer in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2006, 14:41
  4. drilled and grooved brake discs
    By Beavis in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2005, 13:47
