Thread: sump guard
    Regular Member wstwatson's Avatar
    Oct 2007
    wales
    Default sump guard
    hello, i need some advice, i want to change the oil on my 54 plate siggy, just looked under car and it has a sump gaurd does anyone have any pics or advise how to remove it
    Scunthorpe
    Trim : LS
    Engine : 2.0 DTi
    Year : 52
    on my 52 vectra diesel there is 2 or 3 locking screws that need to be undone half (or a full) turn and a flap hinges down revealing the sump. I had to jack the car up to get to it and ended up bruising my shoulders. The sump plug on mine had a Torx (or TXstar) fitting. Also the oil filter on mine is accessed from the top and needs a big socket to undo it properly - I struggled with grips but did it in the end. I also covered my drive with oil as my small container was in the wrong place.
    Oct 2007
    wales
    Default Sump gaurd
    Any pics out there would be a great help
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Put your car up on axel stands (dont use the oem jack use garage equipment) Undo the shield, should be 3 screws at the top, half turn to undo then lower the back of the shield where the screws come out and pull towards the back of the car, that will reveal the sump plug. to get that off you need either the hex key or the torx bit. smack it a few times with a rubber mallett to losen it then unscrew. easy if it decides to come off. If it doesnt there is an oil sender at the front of the engine and simply take that out and raise the rear of the car slightly
  1. Sump Guard broken ... mega expensive !!
    By The Flying Banana in forum Bodywork & Interior
    Last Post: 28th November 2011, 11:11
  2. Dog Guard
    By Matt&Jemz in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2008, 10:26
  3. Dog Guard
    By addyboy1982 in forum General Chat
    Last Post: 27th July 2008, 15:23
  4. Dog Guard Help
    By purple170503 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2008, 22:57
how to remove a sump guard cover on a vauxhall insignia 2010 model
vectra c removing sump cover
