Thread: plug light
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    Default plug light
    the coil light.. plug ?? on my cdti comes on in morning but if i turn engine off and back on after driving it the light doesnt come on should it as the lad at work has same car and engine says his does it now and again also tonight i have a noise coming from passenger side of engine like a rattling when engine turned off seems noisier than normal to didnt take long for problems to happen
    glow plug light even haha
    Glasgow
    The glow plug light pre heats the glow plugs when the engine is cold, i.e in the morning it can be on for a few seconds and when the engine is warm it should come on with the ignition and pretty quickly go off. Dont worry this is normal, or even browse your manual and it will put your mind at rest
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    i was lead to beliveve that the glow plug light only came on when the outside temp was less than 2oC
    comes on for seconds in morning but after thtat it doesnt i am sure it used to though if i drive to work ,, 15 mile then turn off then try it again staright away it doesnt come on
    Regular Member bigun's Avatar
    Feb 2007
    Newcastle UK
    It won't come on after you've driven as the engine is warm and doesn't need to pre-heat anymore.
    sound but still got a clutch proble makes a noise when pressed half way going to get it in next week hopefully haha have to have a see of ur car as havent seen it yet has it a private plate on as saw 1 round ur way with private plate with lass driving it
    If it makes a rattling sound when pressed half way down then it sounds like the DMF is starting to play up. Another reason I didn't get a 1.9
    under warranty so will get fixed free .. well it had better or i wont be happy with whoever see,s to me if it s a male
    Feb 2007
    Newcastle UK
    Quote Originally Posted by willoftoon View Post
    Hasn't got a private plate on but you'll recognise it when you see it. Edition 100 with shiny shiny 18'' alloys on. Stands out a bit from the norm. (I live in Benton now so not quite as local as I was!)
  1. No Glow Plug Light. Help!
    By M65 in forum Engine & Drivetrain
    Last Post: 4th December 2012, 18:25
  2. Glow plug light
    By mrpoochie01 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 06:37
  3. No glow plug light
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2010, 18:14
  4. glow plug light
    By gary the box in forum Engine & Drivetrain
    Last Post: 14th December 2009, 21:19
  5. glow plug light
    By learoy69 in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 17:59
