Results 1 to 10 of 11
Thread: Speedo out by at least 5%, what can I do about it???
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default Speedo out by at least 5%, what can I do about it???
    Hi all,
    my speedo is out by at least 5%
    When the satnav says constant 50 mph my speedo says 55mph.
    The wheels I have fitted are 225/40/18's 8J
    I had the same problem with my previous wheels 215/50/17's 7J
    Does anyone know what setting have I got to choose from in the ECU via Tech 2?
    And which one to change it to?
    Regular Member shan's Avatar
    Setting 2 is for 17,18 and 19" rims.
    Setting 3 is for 20" rims.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Whats setting 1 then Shan?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    So if my speedo is showing more than it should be which setting should I use?
    South east
    If your speedo says 55 when you are actually doing 50 then that's 10% out, not 5%. However, the law says speedos can over-read by up to 10%, but mustn't under-read at all. Hence many speedos do over-read from new so as to stay the correct side of legal.
    [Ex]Admin Duncan's Avatar
    Exactly
    If it bothers you you can get it adjusted with Tech 2 as you said. 225/40/18 is not one of the sizes listed as an option, from memory, as it's not a size listed by Vx - while 225/45/18 is. You'll have to use the option where you enter the tyre circumferance. You can either get that from an online tyre calculator, or wrap a bit of string around the tyre and then measure that.
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    why does it bother you so much as all cars are the same,go by a sat nav unit if you must know your exact speed mate
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Mines 1mph out @ 30mph.... who cares.
    Sorry mate i got that wrong.
    16" 17" is setting 1
    18" 19" is setting 2
    20" is setting 3.
    When i had mine done at MPG. He told me he changed mine from 1 to 2.
    from 17" wheels to 19" wheels.
    So i presume your's is set to 1 and needs to be at 2.
    Jul 2006
    How strange is that?
    Just for info, because I checked it when I changed my wheels, 215/5017 are only a fraction of a mm different to 235/35/19.
    215/50/17 Circumference 2031.98 mm
    225/45/17 Circumference 1992.71 mm
    225/45/18 Circumference 2072.5 mm
    235/35/19 Circumference 2032.92 mm
    The 205/55/16 and 215/55/16 are very different, so would need Tech2 to change calibration, but I can't see much difference from 17" up to 19"
  1. GPS v SPEEDO
    By savage. in forum General Chat
    Last Post: 20th April 2009, 14:23
  2. no speedo
    By frazandsaima in forum Engine & Drivetrain
    Last Post: 25th January 2009, 23:53
  3. Speedo..
    By C19_CJB in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2005, 15:37
