Results 1 to 10 of 26
Thread: Sat Nav Upgrade
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Default Sat Nav Upgrade
    My car is an 06 SRi with out sat nav and a pants CD30
    So can someone tell me what parts are needed to upgrade it to sat nav?
    I've found a complete donor car with Nav fitted, same SRi model but 07 year, so assume everything will swap over?
    Is it an easy mod if I have all the parts?
    Regular Member shan's Avatar
    The SatNav CD70 will need to Tech2'd out of the donor car and into your's for it to work. I carn't see why it will not be ok.
    Don't forget you need the GPS ariel off the other car to
    May 2008
    Bucks
    Quote Originally Posted by shan View Post
    Yep the idea is to get all the parts.
    Is there a list of parts req and locations, so I dont miss anything?
    Here, there and every where!
    CD70, screen, gps unit, probably the loom and a couple of Tech2 sessions should do the trick
    Normally it would be a nono due to the cost but as you have all the bits in a donor car it "should" be do-able.
    Pics and a "How2" if you are successful
    Sunny Dartmoor
    Will be watching this thread to see if its possible..........
    Nov 2007
    Valkeakoski
    I'm interested in doing the same swap.
    CD70 units are available as well as GPS antennas but how about the cabling? Is it included in the radio antenna cabling or should it be installed afterwards?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by glenboy View Post
    Dont you have the old cdr2005 or equal.. then its the ncdc option you have to go for... (opel denmark qoutede me 4500£ if i wanted the cd70/dvd90 option and 3500£ if the NCDC option)
    Sunny Dartmoor
    Thats alot of money Ken,was looking at spending about £220 max...........
    Engine : 2.2 Direct
    well could be done.. if you get all parts from ebay.. the screen is the most expencive (could be a brick from ebay) but ndcd would work if just code follows.. its not much "our" old cars are missing to work.
    Sunny Dartmoor
    What ndcd ken??
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. gid upgrade
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 16:48
  3. Looking to upgrade
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 20:17
  4. upgrade on upgrade
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 23:27
  5. upgrade done what next ?
    Last Post: 19th April 2009, 22:46
