Results 1 to 10 of 26
Thread: Electric Shower Problem!
    Regular Member aaruck's Avatar
    Cheshire
    Vehicle : Insignia
    Default Electric Shower Problem!
    This has happened twice now... part way through a shower the shower stops! This morning I noticed the 'low flow' light had lit up.
    The water is flowing happily through the taps but the electric shower isn't work.
    When it happened last time I left it and it started working again a while later.
    Does anyone know what this could be?
    Ex-Staff Full Member Taffyopel's Avatar
    Oct 2007
    Horley, Surrey
    Mine does this but only when i've got the washing machine going????????
    Snowman, you got your ears on?
    Cheshire
    Vehicle : Insignia
    Nothing else was running this morning.
    Sunny Dartmoor
    The pump in the shower maybe,could be a loose connection inside the unit....
    Birmingham
    Quote Originally Posted by glenboy View Post
    . I had this about a year ago, eventually the pump packed up!
    Bye bye Vec B
    - Hello Siggy!
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Does it have a pump? - Electric showers (rather than power showers) are just mains pressure feed so it sounds like there is some flow problem. Do they get furred up inside eventually? Are you in hard water area and do you have to descale your kettle frequently?
    Birmingham
    Quote Originally Posted by vxvirgin View Post
    Dont need to descale kettle. Mine was a Triton box and it started leakeing the once, then got that sorted, then another problem-had it checked and was told it was a water flow problem, then 1 month later the pump went.
    Im pretty certain they all have a pump!
    Bye bye Vec B
    - Hello Siggy!
    Cheshire
    Vehicle : Insignia
    Sounds like a need shower required then? How much are they?
    Sunny Dartmoor
    They start at about £50-60 right up to £300,depends how much you have to spend really, then it needs to be fitted by a qualified electrician.......
    Jan 2008
    Lincs
    Year : 57
    Mileage : 100k+
    Sorry - that was question for the original poster. They don't all have a pump.
  1. Replies: 23
    Last Post: 16th February 2012, 16:19
  2. Electric problem !!!
    By m.service in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2011, 13:42
  3. Electric Window Problem
    By TrevF in forum Bodywork & Interior
    Last Post: 19th October 2008, 15:15
  4. Electric mirror problem.....
    By sonic in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 00:36
  5. electric window problem
    By jon ixi in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2007, 23:23
