Thread: Metallic noise when turning
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    Default Metallic noise when turning
    have developed an annoyind mettalic noise/rubbing/ squeeking only when turning hard left... havnt had the wheels off yet but is their likely to be an obvious problem?.. or any suggestions as to what to look out for?.
    Regular Member jamesr's Avatar
    Lancashire
    Quote Originally Posted by Dwabo View Post
    Possibly the shield on the front discs, it is very close to the disc, and can touch the trackrod end which pushes it onto the disc.
    Or maybe needs the power steering fluid topping up?
    if its the shield..is it an easy fix?..what needs to be done?..
    power steering fluid is fine btw..
    its deffinately a mettalic rubbing.. and does sound like a thin piece of metal by the way its echoing if you get what I mean..
    Jun 2007
    Kilmarnock
    Hi,
    I've got a vectra GSI and funnily enough it's just developed this exact fault!!
    Started when i turned hard left and now i get a "scraping" sound constantly from the front right wheel. Happens even when brakes applied and they're new anyway.
    Just went to take wheel off and snapped my lock nut removal tool
    Need to order new one from dealers...
    Anything i can do with wheel on???
    Roddy
    Lancashire
    If it is the shield its at the bottom half of the disc, attached near caliper.
    Take of the wheel and simply bend away from the disc.
    Mine was abot 2mm away from the disc when it was rubbing. Simply bent it away to about 10mm - no more rubbing!
    yep..mine is same wheel too.. right hand wheel..
    will try that tomorrow then.. hope its a simple easy fix!!
  1. metallic scraping noise when turning left
    By brasch in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2013, 01:07
  2. squealing noise when turning right.......
    By jinkie in forum Suspension, Wheels & Brakes
    Last Post: 5th October 2012, 20:38
  3. Noise when Turning Ign Key
    By Redviper in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd February 2011, 14:00
  4. Crunching Noise when Turning
    By Sean-2.2Direct in forum Suspension, Wheels & Brakes
    Last Post: 15th May 2010, 18:46
  5. Metallic High Pitch Squealing Noise
    By CarlM in forum Suspension, Wheels & Brakes
    Last Post: 12th June 2009, 20:11
