Results 1 to 2 of 2
Thread: PDF
    Regular Member wstwatson's Avatar
    Oct 2007
    wales
    Default PDF
    can anyone tell me where the PDF is and when the car has an oil change whether or not this is to be changed,
    [Ex]Admin Duncan's Avatar
    You're meaning DPF? Diesel Particulate Filter.
    It's situated in the exhaust system just behind the cat normally. It doesn't need to be changed as the way it works is that it burns off the soot it has captured by increasing the temp in the DPF. The only reason you'd need one changed is if it was faulty.
    Looking at your profile it says you have a 2004 1.9. I'm pretty sure yours won't have a DPF anyway in that model year .
