Thread: ECC Reset??
    Regular Member colalowe's Avatar
    in the North
    Default ECC Reset??
    Does anyone know of a reset function for the ECC aircon control??
    On my Omega you pressed the OFF and AUTO and held them for 10seconds and that reset the system and flaps.
    Is there a similar function on the Vectra? The split temp function dosn't seem to work on mine even though the display has different temps for Driver/Passenger. If you lower or raise either the fans on both sides increase.
    Regular Member bigcarman79's Avatar
    Jan 2008
    Pontefract
    Press the passanger side heater control knob, this then allows you to have dual zone again....press the drivers side heater knob and it puts it back into a common area heating setting. I found this out by accident
    Quote Originally Posted by colalowe View Post
    I thought there was only the one fan, and it was only the temperature that varied. Thats how it seems to work on my 2006 Elite.
    in the North
    I have tried that but even though the temperatures are showing different there doesnt seem to be a difference when you put your hand over the vents?
    Jul 2006
    Depends on the temperature difference - in my handbook it says never to have more then 2 deg difference between the driver and passenger, but the ECC will do much more than that.
    The other night I had Sam in the car, she was cold (because she's a woman) and I was melting (because it was red hot outside ). My side on 18 deg, hers on 24 deg, and it worked fine, ice cold air from the vents on my side and nasty lukewarm air from the vents on her side.
    The fan speed seemd to be the same, just different temperatures.
    HTH
    Jan 2008
    Pontefract
    Have you tried disconnecting the battery for about 20mins...it may reset it
  1. ECU reset
    By wilson002 in forum Electrical & ICE (including SatNav)
    Last Post: 28th March 2011, 19:15
  2. Sat nav reset.
    By welshboy in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 03:12
  3. EML reset
    By paul_sri150 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 14:15
  4. ECU Reset ????
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2007, 14:36
vectra c climate control reset
vectra climate control reset
vauxhall omega heater reset
opel vectra c climate control reset
vauxhall insignia heating reset
vectra c climate control ecc
how to reset vectra climate contro
insignia heater not working do reset
opel vectra c clima reset
vauxhall omega climate control reset
zafira aircon reset
opel ecc resetten
vectra c air con reset
opel vectra c ecc resetointi
vauxhall omega reset ECC
ecc vectra
vectra c heater reset procedure
vectra c signum ecc
