Thread: injectors cleaner
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default injectors cleaner
    does anyone know how to use injector cleaner spray do i have to spray it in the air intake while the engine is running i did this last time and it cut out
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Injector cleaner spray?
    Do you mean the foam stuff you spray directly into the air intake with the ai box removed?
    Not seen an injector cleaner spray before.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Never heard of it either, and don't know how spraying anything into the air intake could clean your fuel injectors effectively. I suppose it could remove some surface dirt on the outside of the housing, but what's the point of that? It's the injctor tip and internals you need to aim at.
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    mate, if you can get it... protec 2000, it aint cheap but it works... put it in when the tank is low run it till nearly empty. Or even better neat!.
    This will shift any stuck cr8p.
    Other here have used stuff like STP etc.. all are ok, but use it as neat as you can for it to work.
    goodluck
    South east
    I use STP (the silver bottle is best), cleans injectors, valves etc, BUT use it at the correct dilution, i.e. one bottle in a FULL tank. Only Cataclean recommend putting it in an almost empty tank.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    chhers guys the chap in the shop told me to spray it directly into the buterfly valve at the back of the engine when you remove the air intake valve i think its the throttle body. what it is when i start my car up it fires up first time then trys to cut out then the revs shoot back up then it trys to cut out again it normally does this 3 times and when the choke finishes its fine. i took it to the dealer cus my emission light was on at the time they said they reset it and no fault codes where present but they said it could be the ecu
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    aint that easy start?
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Sounds like carb cleaner to me, kep the revs up and you will be fine, you will see the cr@p smoke out of the zorst. This stuff deffo wont clean the insides of the injectors though, as said just the additives you put in the fuel tank.
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    take it back... swop it...
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    sorry my mistake its called wynns proffessional formula direct injection power 3 aerosol inlet and valve cleaner for petrol engines. its for start up problems what it says to do his warm up engine and take out the air filter and spray at regular intervalsinto the air systemthen run engine up to 2000 rpm but when i spray it in the engine cuts out
  1. Injectors
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2011, 10:49
  2. Carb Cleaner / Inlet Cleaner 150 CDTI
    Last Post: 19th July 2011, 09:50
  3. Injectors? help
    By Ean in forum The 'Off Topic' room
    Last Post: 26th October 2009, 12:56
  4. Gets cleaner and cleaner shinier and shinier over time..wow
    By hertscol in forum Quick Photo Album
    Last Post: 25th September 2009, 08:10
  5. Replies: 7
    Last Post: 2nd July 2009, 17:51
