Results 1 to 10 of 13
Thread: Steering Play
    SUFFOLK
    Default Steering Play
    Has anybody else experienced issues with steering play on the facelift Vectra C/ Signum. The steer wheel when centred can be moved very slightly from side to side without effecting the road wheels. It only very slight but was not there originally. (Signum 07 ~18k miles)
    I've also noticed this on the Vectra C hire cars I get from work. The low mileage ones under ~8k miles have fairly tight steering with minimal slack. The ones with around 14k plus usual have a bit of slack like my Signum currently has (had one or two hire car vectras with lots of slack)
    Has anybody experienced this or had it sorted by the dealers under warrenty etc?
    Jul 2006
    Mexico
    I guess you can remove the air bag of the steering wheel an tighten the nut.
    Feb 2006
    Dorset
    sometimes mine plays silly bugggers mid turn it feels like the wheels are not pointing the same way one is trying to drag the car one way while the other does the opposite , also it weighs up badly in the corners and the back end bounces like a pig on a bouncy castle...
    Regular Member Matt's Avatar
    in a 3 bedroom house
    yes mine did when i first got it took it to the steelers and there was some clip missing. take it and tell them mate
    hope that helps
    South east
    It won't be a loose steering wheel - the steering column is splined. It'll be worn bushes or something similar.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Track rod ends if you move the steering wheel and the wheels dont move quickly enough
    SUFFOLK
    I was thinking along similar lines but always good to get an ideas if other have had similar experience.
    Have booked into dealers for a look see later in the week. Fingers crossed, no more slack when it comes back.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I had one replaced on mine at 60k, passenger side. Been told this is common for the passenger side one to go for some reason.
    SUFFOLK
    Got it back last night and dealer has done a good job of fixing it.
    Turned out to be the Nut securing the steering wheel to the shaft had slipped just a little. [New nut and slightly more lock tight this time round]. Think they also checked and tighted the bolts of the knuckle joints.
    Birmingham
    Quote Originally Posted by DennisTheMenace View Post
    Presumably you have had it tracked? I had a similar issues with mine, tracking was out and the back was jumping about! over!
    Bye bye Vec B
    - Hello Siggy!
  1. Replies: 6
    Last Post: 13th March 2011, 10:47
  2. Steering Play.
    By mattDY57 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2009, 22:37
  3. Steering play
    By Fozman in forum Suspension, Wheels & Brakes
    Last Post: 30th December 2008, 11:51
  4. Play in steering
    By SJG in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2008, 10:26
  5. steering play
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2007, 21:39
vectra c steering knuckle feel like it loose
vectra c steering p ay
