Results 1 to 10 of 21
Thread: Kerbed alloy - is tyre safe ?
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    Unhappy Kerbed alloy - is tyre safe ?
    how on earth did I manage to do this ?!
    well whats done is done but I need advice regarding the tyre,
    is it safe, can it be repaired ? do i need to put the space-saver on now etc etc, will ring around tomorrow for a new Avon (both front avons have plenty of tread on the front)
    Northampton, UK
    OUCH! I would say for defo' get tha changed! It's on the wall so it can't be repaired!
    Regular Member Robbie69's Avatar
    I'd get that changed not good on the side wall!
    Regular Member shan's Avatar
    Yes i'd change that as it's into the wall of the tyre . I curbed my wheel on sunday i know how you feel mate.
    Regular Member joules2.0t's Avatar
    surrey
    Trim : SRI
    Year : 53
    Change it mate. Go round a corner a tad too fast and it might pop off the rim!
    Apr 2008
    Staffordshire
    Quote Originally Posted by joules2.0t View Post
    oh dont say things like that!
    surrey
    Trim : SRI
    Year : 53
    Sorry m8 - don't want to put ideas in ya head.
    That is a big ol chunck o rubber tho! If it were me I would change it.
    Excellent pictures
    It looks like that tyre has rim protectors
    If so, then there is usually an additional ply
    Drive around locally and look for a big pothole
    Take some photos of it, then submit it to your local authority along with the photos of the damage to the aloly wheel and tyre
    When the tyre gets replaced, keep the tyre as evidence
    Hertfordshire
    No, it won’t come off the rim, the bead that holds the tire on is right on the edge of the tire, not in the sidewall you can see.
    Going by the first picture, I wouldn't panic, the cut looks like it is just in the rim protector part of the side wall, and it doesn't look deep enough to have damaged the tyres structure either.
    However, to be on the safe side, if you are unsure, then yes change it.
    If the tyres structure is damaged then it can lead to a bulge in the tyre, which ultimately if left unnoticed can cause a blow out.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Id risk it... i've had worse till tread went and change the tire...
    its not too bad or even down to the wall, and the walls are much stronger than the tread, if have the money, change obviously,if not. give it a few months. it'l be fine....
  1. Tyre Sidewall Damage, still safe to drive?
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 24th March 2012, 18:58
  2. kerbed alloy
    By williams in forum Insignia car chat
    Last Post: 1st April 2009, 15:01
  3. Welding an alloy, is it safe?
    By James C in forum Suspension, Wheels & Brakes
    Last Post: 30th July 2007, 19:56
  4. Kerbed the Alloy..Replace or Repair
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2006, 11:07
  5. kerbed alloy
    By david-bell in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2005, 23:22
kerbed alloy
