Thread: Help found fault but wheres the part
    Regular Member PeteRs's Avatar
    here or there
    Default Help found fault but wheres the part
    right found out the fault on my car its the fuel rail control valve but cant find it i keep unplugging sensors but still dont know where correct 1 is thanks
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    uploading a piccy for u
    Item 3 is what you want
    Detach pressure regulating valve (3) from pressure reservoir
    Disconnect wiring harness connector.
    Unscrew pressure regulating valve
    – Unscrew at hexagon (2)
    – Counterhold at hexagon (1)
    here or there
    thanks dean
    here or there
    can i just replace this part not the whole rail then & can i do the job without disturbing the actual rail thankyou
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    Not ever done it myself but looking at the piccie it sure seems that way doesnt it
    here or there
    well got the part off so now have to see how much VX are going screw me over for this part thanks again Dean
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    No worries mate, glad to help
    here or there
    well the code reader got it wrong it was'nt this part & it still dont start however i put ezee start in & it did fire up so its getting no fuel thru going have to try again or send it to VX
    just a thought i had just put fuel in at Asda 2 mins had travelled maybe 1/2 mile then it died i never have less than 1/2 tank fuel in so no dirt should have been sucked up but if its blocked where other than the filter would it be blocked
  1. Wheres the fault code plug?
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2012, 14:00
  2. Found a part ermm help!!!
    By delboy2028 in forum Vectra C / Signum Car Chat
    Last Post: 31st March 2011, 21:46
  3. bobby-tupper - Wheres the Part 4 of the Neighbours
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 12th August 2009, 21:02
  4. another fault i found out
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 22:35
