Results 1 to 10 of 15
Thread: Is your Cdti's Performance Consistent ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Is your Cdti's Performance Consistent ??
    54 Plate Cdti 150 Estate.
    Now, My car has had lots of bits replaced
    Inlet Manifold
    AirFlow Meter
    OverBoost Valve
    Map Sensor
    Thermostat
    Egr Valve
    But to me it seems to perform inconsistently (But it may just be me)
    When it is perfoming TipTop it feels like somebody has attached another spring to the Throttle (Strange you might think) The throttle feels tighter, The engine is more responsive, You don't have to press it as far for it to lurch forward, if you get me ..
    When i feel the car is not performing TipTop the throttle feels lighter & you have to load it up further to get it to perform..
    My Mrs as a passenger says it still feels powerful but to me as the driver it feels lame & flatter & there appears to be a distinct difference in how the throttle pedal feels, So much so that you do Notice/feel it
    Does anyone else have this ??
    Dean
    I notice quite a difference depending on weather and time of day
    Best performance seems to be on cold dry nights, typically between 02:00 and 06:00
    Worst performance seems to be on warm wet days, typically between 14:00 and 19:00
    Jul 2006
    I swear that the harder I drove mine, the better it ran. If I let it chug around town for a couple of hours it seemed to lose all its enthusiasm. Almost as if it was somehow adapting to how I drove...
    Strange...
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Never have any problem with mine 1.9cdti 150 with BSR remap, decat and K and N panel filter. Always willing to go at any speed. I think the Estate has the dreaded DPF (Diesel particle filter) and I believe this can cause lower perfomance on and off when it regenerates. not sure tho but someone will be along to agree or disagree with my statement
    Here, there and every where!
    Quote Originally Posted by parapaul View Post
    Apparently the ECU does learn your driving style How true it is and what difference it actually makes i don't know
    Jul 2006
    The DPF doesn't actually detract from the car's performance - it wrecks your consumption for the time that it's regenerating but the ECU must compensate because if anything, the car seemed more responsive during the burn.
    HTH
    Nov 2007
    Staffordshire
    Strange...
    Paul.
    I did think that, As i gave it some Pig last night & this morning & now it feels friskier !!
    trouble is with today's roads & traffic , you do spend more time crawling So if that is the case on the adaptive Ecu learning front we are all Doomed !!
    My average speed on the Onboard comp is a staggering 27 Mph
    As for the Dpf, It does seem to make a small difference when it has regenerated, But not as noticeable as what i described above !!
    I understand that Ambient Temps can make a difference but this feels quite noticeable..
    Another thing i have noticed is the fact the the car also feels torquier with the Aircon running & perhaps put this down to the extra Diesel being consumed !!
    Dean
    Nov 2007
    Staffordshire
    HTH
    Mine seems flat in comparrison during a Dpf Regen
    Dean
    Jul 2006
    Maybe it was my map then...
    Nov 2007
    Staffordshire
    I do wonder if it is all in my head ! Or Foot
    It can feel to perform for days & then it feels flatter, But i do have to do a fair bit ot noise to tail, Low speed driving !!
    Im thinking of purchasing another Map & running with that for a while to compare, But need to know if they would be willing to put my old map back on if i was not happy !! Then there is the expense !! Just for trial purpose's... To see if it is me or perhaps the Map ??
    Perhaps Hypnosis would be cheaper
    Dean
  1. FAO Fellow V6 Cdti's
    By ben_3.0v6 in forum Y & Z30DT Specific
    Last Post: 8th April 2012, 10:09
  2. Been looking at 3.0 cdti's
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2012, 14:46
  3. Vectra 1.9 CDTi regen - This consistent with one . . .
    By Coupe2T in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 16:42
  4. CDTI's
    By akelly1 in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 09:54
  5. De-badged CDTI's
    By markm in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2007, 20:27
