100 amps is the standard alternator rating is that right, whats the highest standard one vec did.
i'm guessing its out of one of the diesels or somet?
I would imagine so... Why?
Diesels generally use higher-amp batteries than petrols, and need a bigger alternator to charge them. Largest standard on the 3.0CDTI I think is about 140/150 amps.
Big ICE install?
When i eventually get my sri - Yes...
My Sri has a 100 amp but some 2.2 petrols have the 120amp. Its hard to tell without getting the manifold off but if the two halfs of the alternator interlink on another than its the 100, but if the two halfs just butt up against each other then its the 120. Hope thats of some help.
cheer's. its the 2.2 i'm after too. i'll have to check when buy...
I'll try and get a pic of the 2. Might be a while though.
cheers...
A pic I have on record mate as im doing the 2.4 manifold mod so need the 100 amp to make the manifold fit easier.
This is the 100 amp.
