Thread: Removing door trim need help!!
    Carterton
    Default Removing door trim need help!!
    I have read that the door panels can be easily removed, I have taken out the screws, popped the clips removed the window winder, and at this point I am told it will just lift off...
    Are there any tricks to this as it seems to have other ideas rather then just lifting off?
    The clips along the window edge are proving quite stubborn.
    Thanks for any help.
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    you got all the screws did you theres 2 behind grab handle and three on bottom of panel i think maybe 2 in the back doors cant remember
    the clips can be quite tricky start from the bottom of the panel and pull quite hard youll here *click* thats the clip disconnecting then you will have to keep pulling till its free then pull it out of window seal aat angel again quite hard
    have to be a bit brutal with her im afraid good luck HTH
    Carterton
    Perfect, only 3 more to do now, and an 1hr before the GP!
    They are brutal aren't, they! and I didn't realise that the internal window sill would come off as well. done now so am happy... untill I have to put it back on!!!
    Apr 2008
    exmouth devon
    again be a bit brutal with it (no hammers) as long as you get that angel right its a easy job the front panels are easier anyway best of luck HTH
  1. Removing door pillar trim
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2010, 18:56
  2. Removing wax from plastic trim
    By DNS in forum Detailing and Car Care Discussion
    Last Post: 11th September 2008, 21:32
  3. removing polish/wax from plastic trim
    By vectragsi3.2 in forum Detailing and Car Care Discussion
    Last Post: 27th July 2008, 23:10
  4. Removing trim from steering wheel
    By Duncan in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2006, 22:07
