Thread: Any idea where fuel cut off switch is
    Regular Member PeteRs's Avatar
    here or there
    Default Any idea where fuel cut off switch is
    need to find the fuel cut off switch as its throwing a fault code any-one no where its located hope this is whats at fault with my car thanks
    Regular Member dan9895's Avatar
    Apr 2008
    exmouth devon
    it says in haynes "located at the rear of the engine compartment in the centre of the bulkhead" i do have instructions for removal if you want the fair easy process though
    here or there
    ok mate i'll go have a look thanks
    Regular Member poves's Avatar
    lancashire
    It's normally a little unit on the bulkhead with a push button on top , normally black or red I thinks .
    here or there
    i cant see it i got a cdti i got big black canister on bulkhead no push buttons to be found yet
    lancashire
    Quote Originally Posted by PeteRs View Post
    That's the fuel filter it should be around somewhere obvious , the top plunger that you press is about the size of a 2 pence piece .
  1. Small 12v Auto circuit for on/off switch for PDC switch
    By markm in forum Electrical & ICE (including SatNav)
    Last Post: 8th October 2012, 23:00
  2. Good idea / Bad idea......?
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2009, 09:09
  3. superchip good idea or bad idea
    By lewrymyster in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 19:14
  4. superchip good idea or bad idea
    Last Post: 26th June 2008, 19:09
vectra c fuel cut off switch
signum fuel cut off switch
vauxhall vectra fuel cutoff switch
vauxhall vectra c fuel cut off switch
fuel cut off switch vauxhall vectra
fuel cut off switch on a vauxhall zafira club 2006
fuel cut off location on vectra
vauxhall signum 2004 fuel cutoff switch
vauxhall signum fuel cut off switch
fuel pump cutoff switch opel vauxhall location
vauxhall vectra fuel cut off switch
05 vectra 3.0 cdti fuel cut off
07 vectra 1.9 fuel cut off switch
vectra 2007 diesel cut off switch
vauxhall corsa c fuel cut off switch
zafira dti 2003 fuel cut off switch
vauxhall vectra cdti fuel cut off
fue cut off systym on vectra c 1.9
vectra b diesel fuel cut off switch
vauxhall 3.0 cut off
vectra diesel fuel cut off location
fuel cutoff switch on vectra ct
vauxhall corsa c fuel cut off switch whereabouts will it be
vectra c fuel.cut off
