Results 1 to 3 of 3
Thread: Timing chain & Oil Filter
    Regular Member old cruiser's Avatar
    slough
    Default Timing chain & Oil Filter
    Was talking to mechanic at a vauxhall dealer today and happened to get onto the subject of the timing chain issues (on Z22SE)and I mentioned about the oil jet side of things and he did say that a revised jet was fitted with larger nozzle which I knew about , but however what he did say was that a lot of the problem was not so much the Jet but the oil filters breaking up as they of paper type and this was causing restriction of oil flow, which kind of makes sense, so probably the moral of the story is to keep a check on these filters!!
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Same filters are on other cars mate and they dont have the problem. The difference in size of the old and new jet is massive and the older type jet has been found in the Vectra C 2.2 as well. Never trust VX when it comes to the Jet.
    Nicking Ya Dinner.
    This is where you enter the world of should I flush or not.
    I personally would flush if the car has done less than 30k regardless of if it's ever been done before, after that it's a bit hit and miss as to whether you could start pulling sludge into the oilways.
  1. timing chain?
    By adammarc in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2011, 19:54
  2. timing chain
    By oldcommando in forum Diesel Engine related
    Last Post: 23rd August 2009, 19:35
  3. timing chain
    By stuartbat in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2009, 17:38
  4. 2.0 DTI timing chain
    By mzctc7 in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2008, 04:23
  5. 2.2 timing chain
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2008, 15:54
vectra c 2.0 dti oil filter timing chain
