Thread: ignition
    Apr 2008
    gateshead
    Default ignition
    how do u remove the ignition barrel on a 2.0 veccy dti
    Wales
    Strip the plastics around the steering wheel so you can access the CIM..
    Put the key into the ignition and turn to postion 1 only not 2 or 3..
    about 2 inchs down the ignition barrel is a small hole, (from looking above the CIM)get a small flat head and have a poke around in there.. Barrel should just pop out then.
    Apr 2008
    gateshead
    cheers mate got it off would a new one have to be programmed to the ecu
    Wales
    If your replacing the CIM then yeah it needs quite a bit of programming.. Unless you know someone with a TECH2 then its the dealers mate.
    Would be a good idea to put the old CIM back into the car, get that "reset" out and write down all three can bus configurations. The rest is then pretty straight forward
  1. 2.2 DTi ignition
    By aladino77 in forum Troubleshooting
    Last Post: 5th June 2013, 10:28
  2. No ignition
    By pud wayman in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 01:26
  3. Ignition came off on the end of the key!
    By dukeminster in forum Vectra C / Signum Car Chat
    Last Post: 7th October 2008, 12:45
  4. Ignition
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 20:21
  5. ignition +ve
    By abz007 in forum Electrical & ICE (including SatNav)
    Last Post: 14th January 2007, 12:22
